LCD Display of Lineage without Sat Nav |
Leodra |
Member No: #3075
Hi all, I've just received today the LCD from vendor who I recently bought the car, and realised that model might not be the right one. Part number is: JCE-EMF C-APR CEM1. Checking in internet it appears as a PSA lcd but not for a C6 model. Trying to fit it in, it is too big. Does anyone know which is the right part number or LCD model for our C6? I couldnĀ“find it out in internet. Should be one like this one: By the way, I would appreciate also if anyone knows how to remove the dashboard frame to fit this display it its place. Thanks in advance. |
Leodra |
Member No: #3075
Well, after analysing the display I got, I arrived to the conclusion that this is the correct one. Now I only have to remove the frame to fit it in there. Any suggestions or guidelines about how to do it? I have found the parts but not how to install it. I donĀ“t want to break it. Regards. | ||
JimC |
Member No: #229
Having done it twice, I know the cover 'pops' off but can't for the life of me remember if I started with a rubber-covered lever to raise the front portion (just under the two vent controls) or by pulling the top cover up & towards myself (away from the windscreen air vent that looks like a curved speaker cover). Once the facia is off, there's 4 screws holding the central panel in place then another two holding the screen. Once you get the first panel off it's a 5 minute job to remove & replace the screen. Good luck! |
JimC |
Member No: #229
PS: the part number I used to get a replacement is: 96609544ZD From: De Vos Autodemontage - Click Here - (excellent & speedy service after I plucked up the courage to do a bank transfer on receipt of an email saying they'd supply it once I'd paid!) |
Leodra |
Member No: #3075
Thanks JimC, it worked very well following your instructions. Finally I could remove Facia, then change the screen was very easy, as you said 4 screws for the central panel and 2 more for the screen. Create an album with the sequence of photos, to facilitate process steps identification, called "C6 LCD Screen Change". Regards |
