Heater/Glow Plugs |
Riffe |
Member No: #1615
Hi there, I am in the middle of starting to change my heater plugs on my C6 2.7hdi 2007 can anyone advise on the removal of the plastic connector on a bank of three plugs, does one just pull the connector off? |
Cisco |
Member No: #1429
Hi there Riffe, Yes, it pulls off but needs a good tug, I looped some material under it at each plug to get some purchase. Good luck with the job and let us know how you get on. All the best, Frank |
Riffe |
Member No: #1615
Thanks Frank, will let you know, just before I do that I have to remove the oil recoverer which I understand also pulls off, funny that, nothing mentioned in workshop manual. | ||
travlician |
Member No: #350
Riffe, I changed mine years ago without removing the oil recoverer, didn't feel the need either. | ||
I had to remove practically everything nestling within the vee; I also had to remove the coolant output tank ('stat housing), the fuel heat exchanger, the front bank's injectors and "airbox" (camshafts' cover)! Four of the six glowplugs sheared, in spite of a good overnight soaking in release oil, heat application and gentle teasing with an 8mm socket! I had to drill and tap them M6 and use a slide-hammer (of sorts) to eventually extract the damnable things... |
vaho |
Member No: #2228
The shearing is a really common issue so it is wise to prepare yourself. If you don´t know when the glow plugs were changed or maybe they haven´t changed at all, it is 90% chance that some of them will brake. My car previous owner changed them in the Citroen dealership and 5 of them broke. Citroen charged him some 3 500 euros because their pocedure requires to take the engine out and basically dismantle the heads. It can however be done without taking the engine out. For that this kind of kit is handy: http://www.lasertools.co.uk/product/5205 |
Riffe |
Member No: #1615
Well I managed to remove all six heat-plugs safely, three were faulty, replaced everything back, thinking that my C6 would now start, no such luck, am now looking else where the as to what the problem is. At least I have eliminated one fault. Any ideas would be welcome. |
What were the starting symptoms (problems?) prior to removing the glow plugs and associated components. Does it crank over, sound OK. regards |
Further to GERRY's question: When cranking, does it sound laboured, and/or does the instrument cluster and the centre LCD flash / blink? If 'yes', then I'd suspect the starter motor... |
Riffe |
Member No: #1615
Thanks gmerry & e3steve, The starter motor seems fine and the engine cranks over as it should, lights stay on. It just does start, sometimes it tries too fire but thats it. Me thinks I will have to trailer it in to someone that knows diesels, even though I have ran a diagnostics, for me it is not easy to analyze why it is not starting. Regards |
Cisco |
Member No: #1429
Hi Riffe, This may sound like a stupid suggestion, however if everything is good and no fault codes are present, then try starting the car with the other key. It is possible that the imobilliser in the key you are using is faulty. All the best, Frank |
