LDS leak above the fuel tank.
AivarVal
Sun Feb 05 2017, 02:47pm
Member No: #1956
Hi all. My beloved c6 started leaking LDS again.It drips down the fuel tank.Is there only pressure tube or backing tube is located also there.Some thouts and pictures please.
Today i lfted the car and looked closely.yes the tube is rotten above the fueltank corner.the tube is very long.what jou think how i must repair that, or only new tube helps solve this problem.i cant belive im first with ho this is happened.
sorry my bad english.
AivarVal
Wed Feb 08 2017, 08:07am
Member No: #1956
Hi all.im sad, no replies so far.i got new idea to put new piece of tube around the fueltank not over it .and depressurise only the back end of the car.what you think,
its duable or not.im not sure about bleeding nessesserity in that case also.
Wed Feb 08 2017, 09:30am
Hi Aivar, sorry to hear you have a hydraulic leak.
Is it on the pressurised pipe to the rear suspension (is there a non pressurised return?)
Do you have access to a drawing showing the arrangement of the parts?
My initial thinking is that it will be very difficult to splice together a new tube into old tube so compare any "repair" solution with replacing the corroded pipe back to the original joint.
regards
AivarVal
Wed Feb 08 2017, 09:57am
Member No: #1956
Yes there is two pipes pressure pipe is steel one and return is made of plastic.
Steel tube is rotted only in one small section .im planing to cut the rotten section out and with hydraulic connectors put the new short piece of tube in.
The original tube is wery long and has lots of corners, so. replace all the tube is very big job (removing the fueltank ,lots of plastics etc) . i hope this fix does the job.
Wed Feb 08 2017, 12:00pm
Hi Aivar, yes I agree from what I can see that replacement of the entire tube section looks like a very long and complicated job.
Obviously you need to find straight runs for the hydraulic connector. Getting a clean, corrosion free external surface will be key if you are to avoid a fatal contamination of the hydraulics. What brand of connector are you going to use (compression double ferrule?).
At the component ends of the steel tubes, Citroen use a proprietary sealing system with a formed tubing flare, a seal and a parallel thread. In 10mm steel this would be virtually impossible to reproduce but I would like to be proven wrong. I have an example sitting on my workbench to remind me of how difficult this tubing connection is.
Let us know your detailed plan.
AivarVal
Wed Feb 08 2017, 06:17pm
Member No: #1956
OK In friday i go to the local garage.i let you know how it went.Plan its to use
copper tube piece between connectors.i hope copper tube is not the problem.
travlician
Thu Feb 09 2017, 03:16am
Member No: #350
I have replaced some steel LHM tubing on my CX once and it bursted after a few months. Since C6 is heavier with higher pressures this is more risk but being rear where pressures are lower it might work. Seek copper tubing for R410 airconditioning systems, this has a thicker wall due to higher working pressures.
Thu Feb 09 2017, 12:48pm
Hi, splicing in to steel hydraulic line is not a simple process so I wish you luck.
IMHO, the tricky aspect is getting a strong leak free connection on to the OLD section of steel line, never mind the connection on to the new spliced in portion (copper, steel, stainless etc). The preparation of the old section is key, as is cleanliness.
It might be possible to ease the job by only having one new/old connection by purchasing a new line (to the component and then cutting this new section at the point where you wish to make the joint on to the old. Advantage, only one connection to be made and you may have a better option in terms of location of the spliced joint.
Again, how you go about cutting the tubing is key: any kind of saw will produce swarf contamination. Another option is a very good quality tube cutter if you have enough clearance to use it.
regards
Thu Feb 09 2017, 01:01pm
Maybe an Eaton 7000 series flareless fitting (theoretically available in metric sizes see extract) might be used to make the splice connection.
regards
AivarVal
Wed Feb 15 2017, 07:57pm
Member No: #1956
So today i sorted this out, with two connectors and 1 metre of copper tube.It went
nicely but when we cut the old pipe then,
there was a wire inside the steel tube.Maybe
somebody knows what purpose the wire has there. Strange enyway.
Thu Feb 16 2017, 11:44am
Great news. Any Photos?
What kind of connectors, manufacturer and model number.
What spec for the copper pipe.
regards
Thu Feb 16 2017, 08:28pm
I believe the wire inside the pipe acts as a damper to slow the flow rate of fluid and act as a cushion, to avoid sudden peaks of high pressure fluid acting on joints and other hydraulic components.
Fri Feb 17 2017, 08:52am
Shaun, do you mean some kind of "water hammer" dissipater?
regards
