Wheel bolt length.
frozenbeard81
Fri Jan 06 2017, 10:00pm
Member No: #2503
just off the top of anyone's head do they know the length be of the bolts. After much much swearing and shouting I managed to remove a fecked locking wheel bolt.
Trouble is now I'm on a break at work needing to order some and I forgot to measure.
I obviously know it's m12 x 1.25 thread and pitch
Did have a quick look on search but couldn't find!
Fri Jan 06 2017, 10:12pm
Forget about the length: just order the OEM bolt which has both flat and conical seats so will do your steel spare and the alloys. Its also made of a high strength alloy and is common as muck at your Citroen dealer since its used on C4s etc.
regards
check this thread for the part number - Click Here -
frozenbeard81
Fri Jan 06 2017, 11:03pm
Member No: #2503
Thanks in advance.
