Radiator bleed screw |
Petrolhead |
Member No: #122
Hi, If anyone has a radiator bleed screw they can spare or know where to get one then I would be willing to buy one. At present I've sealed my radiator with a mix of epoxy (which I think would come out if I turned the screw) and a tie wrap. Thanks Chris |
Chris, I have a spare drain plug. Don't know if that's the same size? Best regards, Phil C. |
Petrolhead |
Member No: #122
Hi Phil, The outside diameter at the widest part is 14mm ~ 15mm so if that matches I guess it's correct. Do you want anything for it, should I pm you? Thanks Chris |
Hello Chris, Was away for a few days, hence no slow response. I'll check it out for you! Best regards, Phil C. |
