Fluid leak from above exhaust manifold on the front head. |
Petrolhead |
Member No: #122
Hi, My 2.7 has been loosing fluid for a few weeks now with the rate increasing. Turns out it is now dripping off the front exhaust header where it joins the cylinder head. Probably the middle cylinder. It doesn't drip while its running because I guess it evaporates first, hence making it tricky to find. Are there any obvious failures above the exhaust manifold on the front of the engine - I can't see anything from above - I'll try and get it on a ramp on Friday. Thanks Chris |
Hi Chris, is it a coolant leak? Can you see the fluid colour? Or is there a diesel smell? | ||
Petrolhead |
Member No: #122
Hi, It is for sure coolant, got it in my hair while under the car. So certainly just coolant. Chris |
Petrolhead |
Member No: #122
Just been out again and had another look. I think actually it is dripping from the collector input into the engine which would make sense. Someone posted about changing that - it's behind the alternator - but I've not managed to find the post. (whilst refilling and bleeding air at the top of the radiator, the qtr turn screw, broke - does anyone know of a source or a sensible workaround) |
Hi Chris, I think your referring to the inlet tank. I've had a bad leak as well, and I'm guessing half the forum has experienced the lovely inlet tank failure at this stage. Its a weak plastic tank that as you have said attaches to the front of the engine. Its about £40 and when you have experienced the job once it's not to bad, you just need to remove the air-con unit and alternator to get up to it. or any decent garage should be able to do it for you quickly. You just need the part: 1336Y2 inlet tank. |
[quote] Hi Chris, I think your referring to the inlet tank. I've had a bad leak as well, and I'm guessing half the forum has experienced the lovely inlet tank failure at this stage. Its a weak plastic tank that as you have said attaches to the front of the engine. Its about £40 and when you have experienced the job once it's not to bad, you just need to remove the air-con unit and alternator to get up to it. or any decent garage should be able to do it for you quickly. You just need the part: 1336Y2 inlet tank. |
Cisco |
Member No: #1429
Hi Chris, This thread has a link to Phil's tutorial to replace the inlet tank together with some relevant associated info. - Click Here - I also broke a radiator bleed screw but managed to find a second hand one. I couldn't find a resource selling a new one without a radiator attached All the best, Frank |
Petrolhead |
Member No: #122
Hi All, Thank you for the great information. Took me a little while to find the link so - Click Here - in case someone finds this. The tutorial really is useful and gives confidence that nothing unexpected will be found. So the million dollar question. I have access to a lift but people are talking of 10 hours which is quite a lot of time - on the other hand 10 hours in a dealer is a lot of money. Is it really 10 hours? How long might I expect a non-citroen specialist (but works a lot on TDV Landrovers) to take doing the job. Thanks again, Chris |
Hi Chris, I'm probably slow, but with the help of a lift it would be that bit easier again. I'd say 2hrs for me if I was doing it again. The speed trick, is to hammer the bolts on the alternator and air-con unit as per the download instructions, and print of Phil tutorial and give it to the land rover garage. They know the 2.7 diesels that's for sure! | ||
vaho |
Member No: #2228
I let the dealer change the thing on my Peugeot 607 2.7HDI. It took them two and a half hours. As they work with timetables provided by the manufacturer, they charged me for two hours, this is the time prescribed. The procedure is the same with Citroen. | ||
Petrolhead |
Member No: #122
Citroen consider it a 3 hour job - which at my local dealer makes it a £380.70 event. I shall have a go myself - what could possibly go wrong! |
Just follow the guides in the link. Remember you don't have to disconnect the air con hoses from the compressor. There's enough length to hang it under the car clear of where your working. Best of luck, Phil C. |
Petrolhead |
Member No: #122
Well closer to 10 hours than 3, if I did it again I reckon it would take me 5. If you've done this on jacks then I salute you. It is relatively easy to put stuff back together so if you do this just keep going until you have it all apart then it's easy from there to get it back together. My notes: 1. I did buy a set of hose clamp pliers which were very valuable. 2. I took the big hose off the outlet with the outlet in place, then pulled the outlet out and removed the small hose. Same procedure putting it back it, insert the hose into the small pipe, fit the tank then place the large pipe on. 3. The hitting the bolts with a hammer thing is a pain - after 9 years and 110K miles the inserts do not slide. For the air-con-compressor I just preserved and hit them off - lots of WD40 lots of hitting. For the alternator I just levered it out of place. Once removed you can place them on a solid surface and give them a proper wack. 4. You do need to remove the tensioner entirely so remove it at the start. I tried not to but the top alternator bolt can't be removed. 5. Grease the tank rubber with vaseline to aid insertion! A professional mechanic not me this - it is water soluble and they use it a lot. 6. I regretted doing it for some of the time - but overall I'd do it again. 7. The water pipe bracket shown in the write up that is on the smaller hose has 2 nuts one you can see in the picture the other you cannot. 8. If you designed a puzzle with difficult to reach bolts then this car would be it, some of them require physical pain to reach and undo. A small 1/4in socket set is useful for some of them. Thanks Phil for the write up, nice to know I hadn't missed anything. |
Well done Chris, Thanks for the updated tips. I've done the same with the alternator to re-position the slides for mounting. Nice to have it done though and hopefully you'll have forgotten how to do it before you have to tackle it again! Best regards, Phil C. |
TonyK |
Member No: #3204
I just replaced my 1336Y2. I took out the radiator and did the top bolt from the front of the engine bay finally getting to use the amusingly titled "Easyview Tradesman inspection camera" that I picked up at a car show (camera on a fibre-optic stick with a light on and separate display. I got to the bottom 8mm bolt from underneath feeding an 1/4 inch drive in from the front. Didnt touch the aircon pump. 5-6 hours to remove. About an hour to put back together |
