Drivers window reset
MrSkillzs
Fri Nov 18 2016, 12:06pm
Member No: #2861
Hello,
my 2006 C6 lost battery power and when I recharged it the window has set his default possition to about 50% open so now when i put it all the way up it returns to this 50% down.
How can I reset it back where it was?
Thank you very much
vaho
Fri Nov 18 2016, 02:01pm
Member No: #2228
From the owners handbook:
After a battery disconnection or if there has been a malfunction,
you have to reinitialise the antipinch function for each window:
Lower the window fully using the control, then close. It will
rise only a few centimetres. Press repeatedly on the control
until the window is fully closed. Keep the control pressed for at
least a few seconds after the window has fully closed.
WARNING
During this operation, the antipinch protection does not work.
