Drivers window reset |
MrSkillzs |
Member No: #2861
Hello, my 2006 C6 lost battery power and when I recharged it the window has set his default possition to about 50% open so now when i put it all the way up it returns to this 50% down. How can I reset it back where it was? Thank you very much |
vaho |
Member No: #2228
From the owners handbook: After a battery disconnection or if there has been a malfunction, you have to reinitialise the antipinch function for each window: Lower the window fully using the control, then close. It will rise only a few centimetres. Press repeatedly on the control until the window is fully closed. Keep the control pressed for at least a few seconds after the window has fully closed. WARNING During this operation, the antipinch protection does not work. |
