Suspension Bolt Part Number? |
Hi all, could anyone help me with the part number of a suspension bolt and its matching nut. Its the bolt that connects the fork on the lower wishbone to the lower bush of the suspension upright (the big vertical alloy casting). There is a download in the technical section that shows the parts and part numbers but unfortunately the lower edge of that document has been cut off. thanks G |
vaho |
Member No: #2228
Is that the bolt? If so the number is 364810, RP 96 838 665 80 And the nut is 693665. |
Vaho, thanks indeed for your reply. Mine had come slightly loose and was making an awful creaking noise which I had put down to the strut (strut replaced but not the cause of the creak). I had the bolt out, there was possibly some wear so a replacement now ordered (must have been sloppy work by my mechanic - must get that torque wrench calibrated). I wonder why there is a replacement part number against that bolt? Anybody know the reason? |
