air filter housing removal
alanr7
Sat Sep 24 2016, 09:35am
Member No: #304
Hi i need to remove the air filter housing on my C6,to gain access to the auto gear box filler cap any tips on how to do it would be most welcome many thanks Alan
Sat Sep 24 2016, 12:20pm
alanr7 wrote ...
Hi Alan,
It's not very difficult, I'm assuming it's a 2.7hdi engine. The description with pictures is in the technical area.
Here's a link:
Briefly, you remove the plastic air pipe which looks like it's coming from the top of the radiator(just pulls away near the rad and up from filter. Then you need to unscrew some bolts, I think it's 3 from the large filter housing body, next you release the various pipes leading from the filter housing body. These pipes are held on by large jubliee clips, I think it's 2 clips to unscrew with a screw driver or wrench and then you almost finished. You finally disconnect the two Maf air sensor connections on the filter body. Now the air filter housing should just lift up with a small bit of giggling. Underneath is the gearbox. Let us know how you got on! Good luck.
Mon Sep 26 2016, 02:23pm
From memory, the screws that hold down the air filter body top half are large crosshead. You will need a Philips screwdriver sized #3.
Once you get down to the autobox, the filler screw cap can be found and it is probably an internal hex head.
regards
PS, any reason why this was posted in the Lounge? Just wondering because you are less likely to get help in that particular section.
alanr7
Mon Sep 26 2016, 06:37pm
Member No: #304
gmerry wrote ...
regards
hi no reason down to not being familiar with the site many thanks for your help
Mon Sep 26 2016, 08:12pm
Hi Alan, I find flexible hex drivers really speed up the work of loosening the 8mm (and possibly 7mm) hex headed screws, like these ones - Click Here -
regards
Mon Sep 26 2016, 08:51pm
Hi Alan, just to add to G's advice, your removing the air filter housing to get at the gearbox oil filler. The technical section also has a PDF to help. If I remember correctly you might need new seals if your attempting to check or drain & fill the gearbox.
Tue Sep 27 2016, 09:33pm
Alan,
If you look down the side of the air filter housing you can see the plug with the torx head. I use a drive with extension bar to loosen it and then withdraw with a magnet. I blow away any dust with compressed air first. Then I use a funnel with a suitable length of pipe to fill. I replace the plug with the magnet and start it on it''s thread, then tighten with the drive. This avoids having to remove the air filter housing particularly if you want to do several transmission oil flushes!
