Cambelt costs |
furriegurrie |
Member No: #2448
Did they vacuum the car too? Maybe they moved the seat forward to vacuum the back and forgot to move it to it's original position? | ||
ul9601 |
Member No: #1975
FreakyFrenchFan wrote ... ...The total cost to change the cambelt, three tensioners, the water pump, the auxillary belt and the coolant came to about £520... That sounds pretty reasonable... FreakyFrenchFan wrote ... ...the timing belt, which looked good to me... Was it due at 140k miles or 10 years? |
FreakyFrenchFan |
Member No: #2057
160,000 normal usage. 120,000 severe usage or every 10 years. My car is 10 years old in February and has currently done 111,000 miles. | ||
Clarification for European, Antipodean and Asian friends, that's thousands of miles (not kilometers) regards G |
furriegurrie |
Member No: #2448
Mine is approaching 10 years too. On 135k kms now. I've order an skf kit for the 2 belts en all tensioners and idlers. Was €240,- so not too expensive. Not in a hurry to change it, the belts I've seen were all in very good nick age wise.... | ||
FreakyFrenchFan |
Member No: #2057
Well it didn't take long! Since the cam belt and water pump change I have been getting a sporadic warning saying "suspension fault". This is despite the suspension appearing to work normally. IE- the usual floaty ride and the ability to manually adjust ride height. Would anything done during the cam belt and water pump change cause any issues with the suspension? | ||
onthecut |
Member No: #2793
Did you perhaps knock the wiring to, or link pin on the RH lower suspension arm height sensor ? It's quite in the line of fire if you're working n the wheelarch. Mike. |
David Hallworth |
It'll probably be the bracket on the wishbone that holds the height corrector link. They corrode and become wafer thin. They're held onto the wishbone by one bolt and cost around £6 each. I had to replace them on my 2.7 at 45k miles. David. |
