Drivers Wheel Arch.
Huutch
Sat Feb 27 2016, 06:06PM
Member No: #2112
A few weeks back I suffered a real bad blowout on the motorway, rendered the tyre useless and in the process it completely ripped away at the wheel arch see attached pictures. What would be the best option to getting it fully repaired? I found this on Ebay - Click Here - would this fit? Or would a trip to Citroen be the best option? Thanks.
Sat Feb 27 2016, 10:30PM
Hi Huutch, the drivers side wheel arch lining comes in two halves: the forward half is hard plastic as per the saverabbits ebay listing, the rear half is made from sound absorbing felt. From your photo, is appears that the felt half has been damaged/destroyed. If this is case, you will need to visit your Citroen dealer. Don't forget to order new metal fasteners as the existing ones will be corroded solid.
PS, someone else can advise if there is a LDW complication.
