What's going on here then
Tue Feb 09 2016, 09:44pm
frozenbeard81 wrote ...
I'll look at the code and report back, I've been on nights so spent all morning asleep! I suspect maybe a fault with the hu then or maybe as stated 2g sim only.
The car is an Exclusive on a 2007 plate though
Mine's fitted with (the dreadfully retarded) RT3; I'm using a Giffgaff 3G SIM successfully...
Wed Feb 10 2016, 01:50pm
Is there a link on 'how to?'
Press and hold the MENU button
go to Radio Telephone
go to Unit Description
should read SW Version 8.31.1.R1 press select button again
SW Version 201211061055
frozenbeard81
Thu Feb 11 2016, 01:30am
Member No: #2503
Ok will do and report back well I did the test and I remember the SW version looking like that cannot remember the long string of numbers though.
Norman
Thu Feb 11 2016, 08:43am
Member No: #364
I use a TPO 3G sim in mine pay as you go still got £16 worth of credit after 12 months of use.
gbl
Thu Feb 11 2016, 10:31am
Member No: #936
e3steve and Norman:
In case my earlier post was not clear: It's not about the SIM being from a 3G provider - it's about whether the SIM works with old 2G equipment or not.
I also use a SIM from a 3G provider which just happens to support also old 2G equipment such as the built-in phone in my 2006 C6.
All I wanted to point out was that apparently not all 3G SIM cards are also supporting old 2G equipment.
frozenbeard81
Thu Feb 11 2016, 05:39pm
Member No: #2503
So that's what version I'm running..
Thu Feb 11 2016, 05:42pm
Same software and firmware as mine....... so that rules that out......
frozenbeard81
Fri Feb 12 2016, 06:50pm
Member No: #2503
Can you 'turn on/off' phone in lexia?
Also if you hold down the green phone for a while you get a cheat code entry screen. Wtf is that all about?!?
Fri Feb 12 2016, 07:26pm
Cheat code, no idea, will look tomorrow.
No, you can't turn it off in Lexia, but I'm not sure about reconfiguring it. My Lexia is down at the moment so I can't check
smorphet
Fri Feb 12 2016, 10:34pm
Member No: #88
This page has a few of the cheat codes that have been worked out. Some of them look like they have the potential to mess things up quite badly, so take care if you're tempted to try any!
Steve.
frozenbeard81
Sat Feb 13 2016, 04:25pm
Member No: #2503
I'll be giving those a miss then!
Sat Feb 13 2016, 05:03pm
That was exactly my thoughts..........
paulx19car
Sat Feb 13 2016, 05:24pm
Member No: #2431
Oooh. That's dangerous knowledge.
Go to page   <<
