Starter motor and pre-emptive maintenance?
Wed Nov 11 2015, 12:15pm
Having watched your videos I'd say the starter motor is beginning to fail. Mine was like that for a good while then, suddenly, it began to crank slower and draw more and more current until, eventually, it was spooking the ECUs with massive voltage troughs.
I reckon you'll need to replace it within the next 5k to 10k miles...
Sevenman
Wed Nov 11 2015, 08:12pm
Member No: #2241
e3steve wrote ...
Thanks for the info.
I'll keep an eye on it, would rather change it before an issue develops. 2 starts like the video today and one unusually long start.
Sevenman
Fri Nov 13 2015, 08:52am
Member No: #2241
e3steve wrote ...
I recorded a properly slow start this morning, see the link below. About 4.5 seconds of turning over before it fired (and then ran smoothly). Compared to about 1 second for the other vids, and what I think it less than 1 second for the other diesel cars I have had. Those 4.5 seconds seemed like a long time.
For context, the car had only been sat for 13 hours after ~ 20 miles of driving yesterday, and the day before that it did 250 miles. The day before that the battery was fully topped-up by my CTEK charger when I was doing car polishing etc. This is all with a brand new original spec battery.
Slow start video
I think the starter replacement may happen sooner rather than later.
Fri Nov 13 2015, 08:52pm
Sevenman wrote ...
e3steve wrote ...
Slow start video
Steep decline. Sphuckt, mate! Look on eBay for one from Premier Factors. I think I've seen them at £150 nowabouts...
Sevenman
Fri Nov 13 2015, 09:52pm
Member No: #2241
e3steve wrote ...
Steep decline. Sphuckt, mate look on eBay for one from Premier Factors. I think I've seen them at £150 nowabouts...
It is variable, had 2 OK starts since then. I had seen those starters on eBay, linked off one of your posts I think?
My Citroen chap is going to find a few options, then I can choose the most powerful... Hopefully it will last for a week.
Sat Nov 14 2015, 08:55am
I only drive mine every weekend, sometimes every other. My battery -- a Varta Silver Dynamic H3, 100Ah/830CCA -- is now exactly two years old this month and is not 'tended' (trickle charged). Since I replaced my old Denso starter motor with the Premier Factors one the old thing spins like sewing machine on steroids!
Sevenman
Fri Nov 27 2015, 07:21am
Member No: #2241
e3steve wrote ...
And now mine does too, see the separate thread I started here:
Lots more starter motor videos!
My early service also included oil and filter, air-con (apparently 450g out, 650g in), freeing-up the partially seized rear brake caliper (hopefully no more squeaking) and some others checks.
Next on my to-do list is some 17" wheels for winter tyres, not sure they come up very often. Ideally alloys, but I could get steel wheels if nothing else is available.
Go to page   <<
