Level Switch for Coolant Reservoir / Degassing Tank |
Hi all, pretty sure that the ECU for the engine on the 2.7HDi does not have the required inputs/outputs for the Cartier low level switch. Note to Sam, the switch is just there to detect a low-low event and is not bothered about changes in the level due to coolant expansion per se. Anyway, integrating the Cartier switch should be possible. If one uses the oil pressure switch as the input warning signal to the BSI, then +5V signal from the Cartier sensor is used to indicate all is good and +0V from the Cartier sensor that there is a fault (ie switch the oil pressure sensor wire to earth). Anyone have experience in using P-Mosfets? Regards G |
Some of the story continues here. | ||
Hi all, here's a circuit diagram to link the Cartier level switch into the BSi as found on the 2.7HDi (or any other variant without a coolant expansion tank level monitoring circuit) Regards G (Click Image to Enlarge) |
ceesix |
Member No: #1464
Hi, I have gathered together the parts needed to install a coolant level sensor in my C6. Thanks for providing details of the set up. However, not being very familiar with electronics, could you supply more detail? Its not clear if the veroboard and relay already exists within the BSI ( does this need to be opened? Or, do they need to be bought and built? How about the oil pressures switch, where is it and how do you break into the wiring? Finally, what about your comment regarding 'back EMF?' How would this be protected against? Sorry to be so ignorant, but looking for a little guidance. Regards, Paul |
eke |
Member No: #624
Hi, I'm in the same situation. I had the sensor installed and have the plug with wires. it would be great to have more information to where to connect the wires. Br Eke |
David Hallworth |
Just to add to this, I was messing around with the Lexia today after clearing a handbrake fault and when I was messing around in the BSI menus I found this... Does that mean that the ECU can support a dedicated coolant level sensor? If so, I wonder if we can find out what pins of the ECU the coolant sensor would be wired into for this feature to be enabled? If it can be done that way rather then piggy backing the oil pressure it'd be handy. David. |
Tjensen wrote ... We must learn form your problems: What is causing clogging and dirt to gather in the air distribution system ? In the simple old times, that would have been backfiring or in the not-so-old times leaks and problems in the engine crankase ventilation system, allowing oil deposits into the system. It should have been nice and clean. - Click Here - |
eke |
Member No: #624
Hello gmerry, I see you are again posting to Forum Is it possible for you to provide some more information on how to connect the level sensor wires to car systems ? Do you have any pictures from connections in your car, it would be very helpful. Thanks anyway Eke |
ChrisW |
Member No: #1335
At 14 years old, with a Chemical Metal bodge (successful – separate thread) on the corroded pipe behind the NSF wheel arch and having read the horror stories about the splitting thermostat housing, I thought I should fit a level warning device on the coolant tank on my C6. Gmerry’s suggestion to connect a float switch to the oil pressure sensor is very clever. But I don’t like float switches, especially on an application like this when the float will always be in the up position, perhaps for years, before there is a leak and the level drops. Crud and slime will inevitably build up on the stem and stiction will prevent the float from falling. There is a high risk that the switch will fail dangerous. I fitted an electronic level control device from ebay (cost about £6 delivered from China). It is based on sensing the conductivity between 2 probes and triggering when one of the probes is exposed because the level has dropped. I had a similar one on my garden pond for many years and it was totally reliable. I drilled two 5.5mm holes in the top of the tank. I took two 1” lengths of 6mm brass studding and soldered a 6mm brass nut on each one leaving enough thread protruding to take another nut in order to connect the wires to the unit. To make the probes, I then drilled a short 1mm hole into the end of each, soldered 2.5mm T&E wire into the holes, cut the wires to length (one to the bottom of the tank and one 30mm shorter). I screwed them into the holes in the tank with an O-ring to seal. I stripped all the insulation from the probe wires to maximise the area for conduction. First, though, test the control unit using a cup of water to check the right terminals to use. Run a wire from the oil pressure sensor to the control unit so that the solenoid switch closes to the car earth at low level and opens when the top probe is immersed in coolant. With the engine running the oil pressure warning comes on when the connection to the ECU switches to earth either through the oil sensor or the level control device. I fitted a test-switch between the top probe and the control unit to simulate the probe being exposed and opening the switch with the engine running triggers the oil level STOP warning. I had not recognised that glycol mixtures are not as good an electrical conductor as water and the excess resistance caused erratic operation. I solved this problem by wiring a 65,000 Ohm resistor across the probe-terminals in the control unit. The number isn’t critical. It should be low enough that the warning isn’t triggered when the reservoir is full but high enough to trigger when it is empty. Perhaps better would have been to place the probes about 2cm apart, not about 6cm as I did, which would remove the need for the resistor. The device needs a 12V feed, switched when the ignition is on, which is easy to feed from the main fusebox, run through a separate 1A fuse. It’s a nice easy job with easy access to everything and will give enough warning of a leak to pull over and check things well before any engine overheating. I now have a bottle of Radweld and a couple of litres of water in the boot just in case. I’ve just driven to Cornwall and back with no issues and no worries about coolant leaks. |
Hello ChrisW, Well done on your mod. Did you see the retrofit of the original sensor and reactivation of the low coolant warning on the central display posted by member Vaho a few years ago? - Click Here - Best regards, Phil C. |
ChrisW |
Member No: #1335
Thanks, Phil. I'm afraid I missed Vaho's posting and would have tried to track down the original Citroen sensor had I seen it. My "sensor" and the original appear to work on the same conductivity principle and both will do the job. If I were to do the job again and the original sensor was no longer available, I would drill the holes in the tank about 1 cm apart to mimic the spacing in the original. I think the main thing is to have a sensor, ideally the original, in the tank because it is an easy and low cost way of avoiding a potential disaster with our ageing C6's. Chris |
Hello ChrisW, Well done on your own installation. Totally agree with the security it brings. I have the VAHO mod installed on our 2.7 and it already alerted me to coolant loss due to the failure of the inlet cooling tank. Would it be possible for you to put together an "instruction" on your modification. The reason I ask is that it would be a proven solution for 3.0HDi owners. The VAHO mod. can't be completed on the 3.0HDi as the BSI alarm menu does not have the "Low Coolant Level" alarm function for the central display available to activate. Hope you'll consider, as I for one will fit it! Best regards, Phil C. |
ChrisW |
Member No: #1335
I am just about to go on holiday and will do this when I get back. Does the 3.0 have a plastic tank to drill into like that on the 2.7? And does it have the wire from the oil pressure sensor as in Gmerry's posting? I will get the details of the device from China. I looked for the Cartier float switch but all I could find was expensive watches and jewellery! Chris |
Hello ChrisW, It has the same tank. I'll check on the wire I'd say it does. I have a Cartier switch. Wonder would it work with your control box? Enjoy the holidays, Best regards, Phil C. |
ChrisW |
Member No: #1335
Hi Phil Very good holiday, thank you. Having looked at Gmerry's circuit diagram for the Cartier, above, I don't think it will work with my control box. The Cartier has some electronics inside that generates a 0 or 5V output depending on the level and this is designed to interface with the ECU for the 2.7 engine. The input to my control box is simply the resistance between the 2 probes. When this is too high the box interprets this as one of the probes being no longer immersed in the liquid, which closes the relay so that the wire to the oil pressure sensor switches to earth, which mimics a low oil pressure signal to the ECU. If you want to use the Cartier, it looks like you need to link it to a 5V micro-relay as per Gmerry's diagram. As you already have the Cartier, this may be the best option, with the 5V relay switching the oil pressure wire to earth. Hope this helps Chris |
