satnav night colour?
Norman
Fri Aug 21 2015, 08:46am
Member No: #364
Hi, my system is a RT4 I've tried all the different colours and options and there is practically no difference so not good, there should be a potenciometer or a resistor in the unit which controls the screen brightness and is possible to adjust or change.
Tech crew you said I could manually adjust the brightness to suit and left a link which I wrongly supposed would give me instructions to adjust the screen, if you meant the user controls next to the screen they are at maximum and are not good enough.
Norman
Fri Aug 21 2015, 11:39am
Norman wrote ...
Norman, I had the same issue on my 3.0 hdi with RT5. It would never go bright enough in strong sunlight and I doubt there is anything you can do about it apart from changing the screen angle which sometimes helps, depending on the suns angle.
m3mpower
Fri Aug 21 2015, 06:07pm
Member No: #662
Hi
Have you tried adjusting luminosity?
Menu, Configuration, Display configuration, Adjust luminosity
Norman
Sat Aug 22 2015, 08:28am
Member No: #364
Yes it set at max. Down here in Torre del Mar it's a bit bright.
Sat Aug 22 2015, 08:39am
Same problem with RT3. Another Citro-versight (along with finger-recesses around the sunvisors)...
Too bright at night if one desires the lovely warmth of the door lighting to be present; poor brightness in sunlight during daylight.
And.... the HUD is barely perceptible if the sun is shining!
Norman
Sun Aug 23 2015, 07:26am
Member No: #364
Door lighting mine barly glows very dim indeed
Sun Aug 23 2015, 11:33am
Norman wrote ...
They all do, Norman. For 'ambient', read 'dim glow'...
Tue Feb 23 2016, 11:01am
Hi, I have the older RT3 system in my current 07 C6. Just wondering is possible to upgrade the old style screen graphics to the last produced version? Is Mirascipt involved as well or at least needed to change up to the newer screen graphics? Any advice here greatly appreciated.
m3mpower
Tue Feb 23 2016, 11:20am
Member No: #662
321dave wrote ...
Hi
Mirascript only works on RT4 / RT5 and RT6
Tue Feb 23 2016, 12:54pm
[center wrote ...
m3mpower[/center]]
321dave wrote ...
Hi
Hi m3mpower,
does that mean the RT3 graphics are fixed and cant be upgraded as such? or maybe it uses a differant scripting code?
many thanks for your reply, and the new Radio facia is still working well!
m3mpower
Tue Feb 23 2016, 01:06pm
Member No: #662
321dave wrote ...
[center wrote ...
m3mpower[/center]]
321dave wrote ...
Hi
Hi m3mpower,
That's correct...
Are you sure you have RT3 and not RT4 ?
Tue Feb 23 2016, 01:21pm
I believe so, not 100% certain it RT3, but the Car was build in late 2006.
m3mpower
Tue Feb 23 2016, 01:26pm
Member No: #662
321dave wrote ...
Check the software version, if it's 6.xx it is RT3
Tue Feb 23 2016, 01:28pm
m3mpower wrote ...
321dave wrote ...
will check it now...give me 5mins
Tue Feb 23 2016, 01:39pm
321dave wrote ...
m3mpower wrote ...
321dave wrote ...
its 6.62
Go to page   <<        >>
