satnav night colour? |
Norman |
Member No: #364
Hi, my system is a RT4 I've tried all the different colours and options and there is practically no difference so not good, there should be a potenciometer or a resistor in the unit which controls the screen brightness and is possible to adjust or change. Tech crew you said I could manually adjust the brightness to suit and left a link which I wrongly supposed would give me instructions to adjust the screen, if you meant the user controls next to the screen they are at maximum and are not good enough. Norman |
Norman wrote ... Tech crew you said I could manually adjust the brightness to suit and left a link which I wrongly supposed would give me instructions to adjust the screen, if you meant the user controls next to the screen they are at maximum and are not good enough. Norman, I had the same issue on my 3.0 hdi with RT5. It would never go bright enough in strong sunlight and I doubt there is anything you can do about it apart from changing the screen angle which sometimes helps, depending on the suns angle. |
m3mpower |
Member No: #662
Hi Have you tried adjusting luminosity? Menu, Configuration, Display configuration, Adjust luminosity |
Norman |
Member No: #364
Yes it set at max. Down here in Torre del Mar it's a bit bright. | ||
Same problem with RT3. Another Citro-versight (along with finger-recesses around the sunvisors)... Too bright at night if one desires the lovely warmth of the door lighting to be present; poor brightness in sunlight during daylight. And.... the HUD is barely perceptible if the sun is shining! |
Norman |
Member No: #364
Door lighting mine barly glows very dim indeed | ||
Norman wrote ... They all do, Norman. For 'ambient', read 'dim glow'...Door lighting mine barly glows very dim indeed |
Hi, I have the older RT3 system in my current 07 C6. Just wondering is possible to upgrade the old style screen graphics to the last produced version? Is Mirascipt involved as well or at least needed to change up to the newer screen graphics? Any advice here greatly appreciated. 321dave |
m3mpower |
Member No: #662
321dave wrote ... Hi, I have the older RT3 system in my current 07 C6. Just wondering is possible to upgrade the old style screen graphics to the last produced version? Is Mirascipt involved as well or at least needed to change up to the newer screen graphics? Any advice here greatly appreciated. 321dave Hi Mirascript only works on RT4 / RT5 and RT6 Regards |
[center wrote ... m3mpower[/center]] 321dave wrote ... Hi, I have the older RT3 system in my current 07 C6. Just wondering is possible to upgrade the old style screen graphics to the last produced version? Is Mirascipt involved as well or at least needed to change up to the newer screen graphics? Any advice here greatly appreciated. 321dave Hi Mirascript only works on RT4 / RT5 and RT6 Regards Hi m3mpower, does that mean the RT3 graphics are fixed and cant be upgraded as such? or maybe it uses a differant scripting code? many thanks for your reply, and the new Radio facia is still working well! |
m3mpower |
Member No: #662
321dave wrote ... [center wrote ... m3mpower[/center]] 321dave wrote ... Hi, I have the older RT3 system in my current 07 C6. Just wondering is possible to upgrade the old style screen graphics to the last produced version? Is Mirascipt involved as well or at least needed to change up to the newer screen graphics? Any advice here greatly appreciated. 321dave Hi Mirascript only works on RT4 / RT5 and RT6 Regards Hi m3mpower, does that mean the RT3 graphics are fixed and cant be upgraded as such? or maybe it uses a differant scripting code? many thanks for your reply, and the new Radio facia is still working well! That's correct... Are you sure you have RT3 and not RT4 ? |
I believe so, not 100% certain it RT3, but the Car was build in late 2006. |
m3mpower |
Member No: #662
321dave wrote ... I believe so, not 100% certain it RT3, but the Car was build in late 2006. Check the software version, if it's 6.xx it is RT3 |
m3mpower wrote ... 321dave wrote ... I believe so, not 100% certain it RT3, but the Car was build in late 2006. Check the software version, if it's 6.xx it is RT3 will check it now...give me 5mins |
321dave wrote ... m3mpower wrote ... 321dave wrote ... I believe so, not 100% certain it RT3, but the Car was build in late 2006. Check the software version, if it's 6.xx it is RT3 will check it now...give me 5mins its 6.62 |
