Suspension bushings and joint replacement guide. |
datmbn |
Member No: #193
I started to get an irritant clunk sound from the front right wheel but could not find no play. However, I could feel a small backlash from the left lower spindelled, but from there, it sounded nothing, moreover had the front tires started to rip awry, and road noise increased significantly. When I took the help of a friend who rocked the car during the time that I felt on all leads, I noted that there were glitches in the right upper spindelled, right steering linkage and left lower spindelled and that there seemed to be cracks in several of the rubber bushings. I decided to change all the joints and bushings (I'm tired of replacing parts which then breaks back prematurely for some other part is worn) here's a pdf how I did. the text in the file is in two languages ??(translated with Google Translate) - Click Here - Had I been able to get by with just changing what glappade? probably! I noticed a difference? yes the car has been ever since I bought it pulled a little to the right, this has ceased almost completely, and that the road noise has been reduced Sincerely, Mats |
magicands |
Great job, beyond my capabilities by a Country mile but others will find this very useful | ||
xmv624v |
Member No: #2292
Hi there. Can you tell me where the LOWER bush in the Pivot arm that the bottom triangle arm fits in it comes from please?? This one in my picture.. The one at the bottom. The actual ball joints are in good order. I have an mot next week and cant find this bush anywhere. Thanks |
Jodyone |
Member No: #1240
xmv624v - I'm not sure if this is the exact same one I bought, but it looks identical (eBay link): - Click Here - There are some pictures of my installation on this thread: - Click Here - It's a well reported job on this forum though! Should be plenty of help available. |
