2.7 HDi vs 3.0 HDi
Kaloteck
Sun Aug 02 2015, 10:51am
Member No: #1271
Hello All,
I've been reading through this nice PDF here:
" SUMMARY : VEHICLE C6 - EVOLUTIONS IN YEAR 2009 (COMMERCIAL LAUNCH - DT20C 3.0 HDI ENGINE WITH PARTICLE FILTER)"
Very useful information, I must admit, but... all those changes and alterations... do they make it a completely new engine? Reliable? Is it any good?
I'm looking for a diesel myself, but after hearing all those 2.7 HDi horror stories...
Sun Aug 02 2015, 11:54am
Horror stories?
Kaloteck
Sun Aug 02 2015, 12:50pm
Member No: #1271
Yes, for example, problems with the camshafts. The designers 'slimming' engine led to "anorexia" crankshaft which often breaks and also likes to knock out or rotate the pan rod. World record weight class (only 202 kg) cost engineers design flaw that nobody does not speak loudly.
David Hallworth
Sun Aug 02 2015, 02:03pm
You talk about horror stories... The thing is, people only tend to join forums to rant and rave about their broken cars.
The number of these engines produced must be massive, the C5, C6, 407 (Coupe, Saloon and Estate), 607 in Europe I believe, Land Rover in the Range Rover Sport and Discovery 3, and Jaguar in the S Type and XJ.
The number of units that have failed versus the number of units that have been produced must be tiny.
David.
Sun Aug 02 2015, 03:11pm
After 90.000 km my 3.0 engine is still perfect, never had a problem. Extremely low fuel consumption and good power. Better accelleration now than 3 years ago, but that is gearbox adaption. And they fixed some of the 2.7 problems as well (alternator clutch is one example, probably the injection/particle filter/turbo systems are better also)
Sun Aug 02 2015, 04:41pm
Kaloteck wrote ...
the 3.0 HDi is a far better engine than the 2.7 so if you can find one, that's the one to go for.
Sun Aug 02 2015, 04:57pm
Kalotech,
Never heard of the camshaft problem. I would hold David's view that the 2.7 engine is very robust. The coolant tank outlet tank is the big threat to the engine coupled with no low coolant level warning. Sadly some owners have been the innocent victims of this, while others of us have had lucky escapes. Long term the 32000km (20000 mile) oil change schedule may also cause problems on higher mileage units, that's why I keep to the 16000km (10000 mile) interim frequency. I was even advised by a Citroen independent to do this, as he could see the extended oil change frequency catching up on C5's.
I now see what C6Dave means about the 3.0Hdi. It is a lovely engine. The Bosch injection makes it much quieter and the max torque at the lower 1600rpm really makes the driving experience different. However, it still has the dreaded coolant outlet tank and no coolant level warning.
But you're in LHD territory where 3.0Hdi are numerically stronger so go for it if you can!
Kaloteck
Sun Aug 30 2015, 01:29pm
Member No: #1271
OK, found one, bought one and very happy with it
I intend to keep it till the end (its or mine), so...
Since they don't make them any more... Do you think it might be a good idea to buy another one just for spares?
Sun Aug 30 2015, 04:19pm
Kaloteck wrote ...
If you can find one cheaply then for the engine/gearbox/body panels and glass it may be worthwhile as new parts sometimes take a long time to arrive via Citroen and you would be off the road....
Sun Aug 30 2015, 08:36pm
Kaloteck,
Comgtatulations. Did you go 2.7 or 3.0HDi?
FreakyFrenchFan
Mon Aug 31 2015, 07:14pm
Member No: #2057
The biggest difference between the 2.7 and the 3.0 is the 2.7 is abundant and the 3.0 is rare as hens teeth. I have a 2.7 and I'm totally satisfied with it.
Kaloteck
Fri Sep 04 2015, 02:14pm
Member No: #1271
cruiserphil wrote ...
Kaloteck,
3.0, MY 2010, full service history, 140 875 km on the odo, 12 000 Euros. The man was actually very happy, because he just hated poor dealer service. Apparently he had to wait nearly 2 months for some hydro-related part and then again 3 months for another. That was too much for him. So, you see, my initial worries remain, because Citroen can't take care of its customers in a proper way.
Fri Sep 04 2015, 03:22pm
Just under £9,000 is a great price for a 3.0 HDi
ecksem
Sat Sep 19 2015, 10:08am
Member No: #626
2007 C6 2.7D Lignage spec being traded at Yeomans Garage(Citroen) Exeter. Car in good condition Arctic silver with black leather interior, 49,000 miles newish battery, good tyres, MOT to Sept 2016. Maintained by Yeomans. Small body repair to Offside front wing but generally clean. Detachable tow bar fitted. Should be able to deal around £4,000. Suggest speak to Andrew Turner (Sales) tel 01392 431 431.
Kaloteck
Sat Sep 26 2015, 06:57pm
Member No: #1271
Admin Dave wrote ...
Yes, it is. You should see the expression on the man's face. He wa actually happy to get rid of this car. Too much time off the road, he said, due to poor spare parts availability, even through proper dealer channels, he admitted.
