Central locking doesnt work with key - Solved -
TycoonX
Sun Jun 07 2015, 04:23pm
Member No: #988
Hi all!
I have bought C6 2.7 HDi 2007. With electric steering wheel and sunroof.
I have problem with central locking. I cant lock doors with key. But i can switch on the lights with key..so battery in key is not the problem.
Central locking has no faults in lexia.
When i drive, the door locks automatically, and when i go out from car, the door unlocks automatically.
But im unable to do it with key.. it also doesnt work in door..its like weared lock.. the ignition lock is also weared.
Any advice?
TycoonX
Sun Jun 07 2015, 06:11pm
Member No: #988
News.. unlocking works..light works.. locking doesnt work.
In lexia i saw that front door lock, requires lock.. maybe front door lock is stuck
drummond
Mon Jun 08 2015, 10:43am
Mine has never worked with the key- I would guess that the central locking and the ignition key have been reprogrammed and the dealer didn't change the door lock.
TycoonX
Mon Jun 08 2015, 04:14pm
Member No: #988
Im planning to disassemble drivers door.. because the handlock doesnt response..its like not connected to door locking unit.. and maybe there is problem.
Door want to lock.. so BSI ignore requirement from key
jumep
Tue Jun 09 2015, 07:46am
Member No: #2125
did you try superlocking? (double press of locking button)
TycoonX
Sat Jun 13 2015, 06:38am
Member No: #988
yes..i tryed all. I disassembled key..all buttons is OK, working..battery ok.
jumep
Sun Jun 14 2015, 08:40am
Member No: #2125
Did not someone configure that there is no locking?
Lexia -> BSI -> configuration
TycoonX
Mon Jun 15 2015, 06:24pm
Member No: #988
Díky! I will check it soon. But in lexia i saw, requirement from front door lock for locking.. so i think the front door lock is stuck. Somebody did something with it ..there is missing cover on the door.
TycoonX
Thu Jun 18 2015, 11:53am
Member No: #988
Door lock working! But remote control still nothing.. lexia doesnt recieve locking signal.. im going to buy new key
TycoonX
Thu Jun 18 2015, 01:44pm
Member No: #988
So - PROBLEM SOLVED -
The door lock was disconected from keyhole, because there was corrosion ..and the actuator simply jumped out.
Second problem was the key, the chip near to microswitch was damaged, ..litlle playing with it and now its working..i dont know how long will mine repair last..but now its ok
New key cost about 130€ ,,key from ebay / resellers..about 30-40€..im going to buy one.
Thanks to all
