Strange brackets under the boot floor
Jarecki
Mon Apr 13 2015, 08:03am
Member No: #2069
As shown on the photo, I have no idea what that rusty bracket is for?
chillmax
Mon Apr 13 2015, 09:01am
Member No: #1648
That's the cup holder for the guys in the factory when they're building the car, they've gotta have somewhere to put their espresso )
drummond
Mon Apr 13 2015, 01:48pm
That was where the main wiring loom ran, or it did on French cars, anyway......
dsharples
Thu Apr 16 2015, 08:17pm
Member No: #119
I noticed one of those on mine too. I did wonder if I'd lost some shielding somewhere!
Fri Apr 17 2015, 06:51am
THere should be a plastic shield covering (not fully) the pair of rear spheres. Mine got ripped off and I had it replaced. - Click Here -
Fri Apr 17 2015, 08:28am
So far, no one has come up with a reason for these brackets!
Does anyone with an early car (2005) has something bolted to these brackets that was subsequently deleted in the build specification?
Jodyone
Fri Apr 17 2015, 09:38pm
Member No: #1240
Who else has them? I don't think mine does. You also have at least one extra exhaust clamp compared to mine- I only know because I replace the lower one in you pic recently (it was rusted out, and consequently the backbox drooped).
Jarecki
Sat Apr 18 2015, 05:56am
Member No: #2069
Yes Joydone, my exhaust pipe was a little bit tuned, because of new Sebring silencer was fitted. The flow is better and more power available.
But the main question is still on. What the bracket is for? Is it very hard job to pump up the car, bow and take a foto?
Fri Sep 01 2017, 07:12am
I'm resurrecting this topic as it's still intriguing me, too.
My 2.7 has this bracket and I, too, thought I'd lost the aft cover for the middle spheres. Not so, it seems. There is no aft cover, according to my local, friendly dealer!
My bracket's condition looked akin to yours, Jarecki, in your opening post. I've since painted it with Jenolite rust converter; it's remained a nice purplish pink since...
Fri Sep 01 2017, 07:15am
Dave-Retired wrote ...
According to the Citroën microfiche description, Dave, the shield is called an "air deflector"...
PHaTGRoB
Fri Sep 01 2017, 04:48pm
Member No: #994
I'm sure mine has this bracket, as shown in Jarecki's photo. I came across it when changing a rusted exhaust clamp. No idea as to its purpose though. Sorry. GRoB.
HiPOL
Sat Sep 02 2017, 03:58pm
Member No: #2699
Every C6 has it. In versions with AMVAR it is practicly usless , it only holds wires. In 2.2 HDi version it additionaly holds height corrector. I guess it was cheaper to keep just one holder for wires and height corrector than design 2.
Plastic shield mentioned by Dave is mounted in another place, at the spheres.
Sun Sep 03 2017, 08:40pm
This picture from one of the pdf in he library, seems to have a plastic shroud over the metal bracket! The plot thickens a bit more!
vaho
Mon Sep 04 2017, 06:39am
Member No: #2228
The same plastic shroud can be seen in parts list picture but it is no longer available as there is no part number:
Mon Sep 04 2017, 05:37pm
Part number 8 will be missing from the list if you entered your VIN, which means only parts suitable for your car are shown.
This would suggest your car wouldn't have been fitted with part number 8 when it left the factory.
If a part is no longer available, it is still listed but has 'NFP' (No Further Parts) next to it.
No.8 is part number 7013 Y6 and for petrol engines only.
When you first go into Citroen Service, just selects parts for C6, then click 'Confirm' without selecting an engine type or body type.
