Shock Repair including AMVAR by Nagengast in Poland |
Hi all, attached is the detailed reply to the questions asked regarding the shock repair service offered by Nagengast in Gdansk Poland. Not having used this service I can't personally recommend but they look sound. Regards G e mail: Thank you for your enquiry and sorry for late reply but I was travelling. Please find below answers to your questions: 1/ How many of these C6 AMVAR dampers have you repaired We have repaired around 100 of shock absorbers to C5, C6 for Polish customers and around 15 units of C6 AMVAR. The repair of C5,C6 and C6 AMVAR is practically the same. 2/ Is it possible to repair a leaking strut, how long will the repair last., is it a matter of replacing seals or does the sliding surface need to be replated and polished. Yes it is possible. The repair lasts around 3 working days. It is a matter of replacing seals and/or replacing or polishing of sliding surface and/or replacing the rod. 3/ How do you achieve internal fluid cleanliness, do you work to any international particle counting standards I don’t understand your question. Could you please explain. 4/ what is a typical repair turnaround time for a strut posted from the UK The repair lasts about 2-3 days. The shipping to UK lasts around 3-4 days with DPD courier. 5/ Do you replace the mounting foam at the top of the shock No, we don’t replace the mounting foam as there is no need to do that. We have never experienced any damages in this part in the restored shocks. 6 Do you have a standard repair cost for a leaking hydraulic strut. The price is 150 Euro per unit. You receive 1 year warranty. You are welcome to post our answers on the Citroen C6 Owners dot Org forum. Best regards / Mit besten Grüßen Monika Nagengast Tel. + 48 609 600 566 PUH NAGENGAST ul. Malczewskiego 103 80-107 Gdańsk POLAND Website: - Click Here - ________________________________________ Subject: Citroen C6 AMVAR Shock Absorber Overhaul and Repair |
speedfix |
I shall be replacing both of mine next year so will have two old units that are misting damp at the mo, not a prob at the moment but the gaitors on both have let go on the shock bottoms so will have two old units to send to them, they do seem to do a though job looking at the clip in the machine shop, maybe they can convert the units without having the amvar so I can have two spare ones for the 2.2 hdi. | ||
Many thanks for that post G. Best regards, Phil C. |
David Hallworth |
Has anybody successfully used these chaps yet? I know someone with a C5 with a leaking strut and my C6 has a damp spot on the O/S front strut as well. Thanks David. |
Kaloteck |
Member No: #1271
gmerry wrote ... 3/ How do you achieve internal fluid cleanliness, do you work to any international particle counting standards To them, that probably sounds like rocket science. |
HiPOL |
Member No: #2699
I repaired my shock absorbers in this company. Both are leaking again after less than 6 months. Conacted them and got information they improved repair procedure recenlty. They are putting additional sealing next to original, since original was not enough and they had some malfunction entries. I`ll send them my shock absorbers again and they should repair it within warranty. | ||
HiPOL |
Member No: #2699
They repaired it second time , and it`s leaking again. I bought new struts and there is incredible improvement in quality of ride and comfort. I think the reason are AMVAR valves. During repair they don`t even check if these valves are OK, they only repair sealing (without result) My advice - don`t repair it. Buy new. |
Thanks Hipol, I have a strut for repair and was going to send it to Nagengast. It's a pity they can't sort the sealing. I'll just take the hit and order new. Best regards, Phil C. |
Resurrecting an old thread but.... Does the system need depressurising via Lexia in order to remove the failed shocker or is there another way to release the pressure AKA the old DS with a bleed screw on the regulator? | ||
Hello Dave, There is a manual method which is detailed in the Citroen maintenance documentation. I can't remember the details as I've always done it through Lexia as it's hassle free! Best regards, Phil C. |
cruiserphil wrote ... Hello Dave, There is a manual method which is detailed in the Citroen maintenance documentation. I can't remember the details as I've always done it through Lexia as it's hassle free! Best regards, Phil C. Hi Phil, your correct, I've also used Lexia to do the release front and back. But if you open the valve I believe on the 70psi center sphere it depressurises the front manually leaving the rear up. |
