satnav night colour?
abrli
Sat Oct 18 2014, 08:14pm
Member No: #1899
hello,
I've been driving around in my C6 for a week now and couldn't help being slightly distracted by the bright satnav map colour. does it have a dark colour option for the night like most satnavs do? if so could you kindly let me know how it can be activated?
cheers!
Sun Oct 19 2014, 06:58am
If you look on the radio unit there is a button that says 'Dark'
Also on the left side of the display screen there are 2 buttons to raise of lower the screen brightness
Sun Oct 19 2014, 08:43am
That shuts the LCD off completely, first press, then, second press, everything except the speedo readout. Third press restores all...
The right-side buttons, Dave; the left-side buttons alter the vertical angle of the LCD.
abrli wrote ...
hello,
cheers!
When in the 'Nav' screen at night, mine inverts the colours -- dark blue background. I think this is achieved via the light sensor in the windscreen(?).
Also when in 'Nav' mode, pressing in the screen navigation chrome knob (in the middle of the 'up', 'down', 'left', 'right' arrows) to reveal a menu, one line of which is something like 'Reduced Screen'; this gives the option to toggle between full display or two-thirds display.
Sun Oct 19 2014, 12:08pm
And via setup you can change background to color/contrast that suits you.
Sun Oct 19 2014, 04:29pm
@e3steve it's driving a left hand drive TA that confused me
spbmssen
Sun Oct 19 2014, 04:47pm
Member No: #1470
You need to upgrade your firmware (assuming it's an RT4 unit). I think you need v8.00 or above to get the dark satnav colour mode.
Rooster
Sun Oct 19 2014, 09:29pm
Member No: #1799
I have the latest version CD pack available if you want to get in touch.
magicands
Mon Oct 20 2014, 06:52pm
My RT3 has a night colour mode that kicks in when the light begins to fail outside, it goes Black and white in effect and is duller.
This however does not impact on the Navigation screen which when used at night stays bright unless you turn the brightness down using the buttons by the screen.
Norman
Mon Aug 10 2015, 08:21am
Member No: #364
The problem I have noticed is down here in Spain with the high ambience light is that the satnave is not bright enough to read the screen it ok at night time and adjustes ok it's just during the day it seems a bit dim and I wondered is there a way of overriding the controls possibly by using the lexia or digibox.
Tue Aug 11 2015, 07:33pm
Norman,
might sound daft but try changing the colours
Norman
Wed Aug 12 2015, 08:22am
Member No: #364
Hi Steve,
I'll give that a try but I like the standard colours just need turning up brighter
m3mpower
Thu Aug 13 2015, 07:39pm
Member No: #662
Hi
You can manually adjust the brightness to suit your needs.
Norman
Fri Aug 14 2015, 07:51am
Member No: #364
Hi m3mpower your link just took me to your web site checking everything didn't take me to any instructions on how to manually adjust the brightness, I have turned up the brightness using the front panel up/down buttons, but it still needs to be brighter during the day, nighttime is OK.
Fri Aug 14 2015, 08:04am
Non of the screens are bright enough in sunlight I'm afraid Norman, just follow the arrows on the HUD
m3mpower
Fri Aug 14 2015, 09:37am
Member No: #662
Norman wrote ...
Hi Norman
I didn't say the instructions are on my website.
By the way, which system do you have? RT3 or RT4 ?
