satnav night colour?
m3mpower
Tue Feb 23 2016, 01:42pm
Member No: #662
Then it is RT3
Tue Feb 23 2016, 03:07pm
m3mpower wrote ...
Then it is RT3
With the RT3 unit, Is the display graphics held on a chip internally?
Thanks anyway for the advice and help. That might lead me to upgrade to the RT4 unit now.
I believe the cables to the screen are differant, and a hardrive would be needed for the sat nav maps.
Would the CD changer need to give way to a hard drive unit in the boot or is the hard drive internal to the RT4 unit itself?
Many thanks again
m3mpower
Tue Feb 23 2016, 03:19pm
Member No: #662
The hard drive is part of the RT4, it is not external...
The cd changer remains the same.
Yes the cables are slightly different, the RT4 does not use fibre optic like the RT3.
Tue Feb 23 2016, 04:09pm
m3mpower wrote ...
If a new cable is required and I think that means a new screen or maybe not? Ill need to start to consider this now I guess. If someone was upgrading from RT3, would it be best or possible to upgrade up to RT5. Is it theoretically possible?
Tue Feb 23 2016, 04:23pm
RT3 Satnav on a CD, CD Changer in the boot
RT4 Hard dsic
m3mpower
Tue Feb 23 2016, 04:42pm
Member No: #662
321dave wrote ...
m3mpower wrote ...
Yes it needs a new screen of course.
Upgrading to RT4 or RT5 it is the same procedure, yes it's possible to upgrade to RT5 with Bluetooth.
In both cases, RT4 or RT5 you can also upgrade to the high resolution screen which is found on some RT5 Systems
2 User said Thank You to m3mpower for this Post :
 321dave (23 February 2016) , cruiserphil (23 February 2016)
Tue Feb 23 2016, 04:50pm
m3mpower wrote ...
321dave wrote ...
m3mpower wrote ...
Many thank for that, ill start planning the upgrade now, as it will coincide with some other center console upgrades due. Much appreciated. Ill send you an email in due course.
frozenbeard81
Mon Feb 29 2016, 01:50am
Member No: #2503
I still wish satnav would go dark on its own accord.
Mon Feb 29 2016, 08:25am
It should do so. Perhaps the photocell (daylight sensor) isn't functioning. Mine goes into night mode at twilight light levels; the map screen background becomes a dark blue/indigo colour.
frozenbeard81
Mon Feb 29 2016, 01:38pm
Member No: #2503
Where is the photocell?
Mon Feb 29 2016, 11:12pm
frozenbeard81 wrote ...
I imagine it'll be in the rain sensor/auto-lighting cluster, in the windscreen and adjacent to the rear-view mirror(?)...
Norman
Tue Mar 01 2016, 10:05am
Member No: #364
Mine also doesn't go dark automatically I have to push the button I tried doing it at night time as suggested but it still didn't go dark the following night.
Tue Mar 01 2016, 11:11am
Mine is non-Automatic (maybe only an adjustmet in brighteness), but this is fine , this is something I want to control myself.
Tue Mar 01 2016, 01:16pm
Norman wrote ...
Hi Norman,
sometimes when you select the function in the menu list ( i did this a few times before I realised what was happening) it sometimes doesn't get properly selected (little arrow tick in the menu box selector before exiting)
 Norman (02 March 2016)
frozenbeard81
Tue Mar 01 2016, 08:53pm
Member No: #2503
Hmm i didnt even realise there was a menu to select it. Probably best checking that first. I too have to oress the dark button.
Go to page   <<        >>
