Cleaning Under The Spoiler
Rooster
Fri Sep 05 2014, 04:36pm
Member No: #1799
Asked my girlfirend to hang out of the rear window whilst doing 80 down the M6 earlier, so that she could clean under the spoiler whilst it was 'up'. She refused
Has anyone any suggestions on how best to do this with the car stationary?
Cheers
smorphet
Fri Sep 05 2014, 05:35pm
Member No: #88
Shortly after switching off the ignition, press down on the wiper stalk, as if to turn on automatic wiping. The wipers will move to the edges of the screen (handy for changing blades) and the spoiler will pop up.
Fri Sep 05 2014, 05:43pm
Remeber to but some oil/grease/rustproofing on the parts in the mechanism. Some of them rust and some will gradually have difficulties moving freely and then there will be problems.... (and costs)
Sat Sep 06 2014, 12:11am
Rooster wrote ...
Cheers
'Tis in the handbook......
JimC
Tue Sep 09 2014, 08:41pm
Member No: #229
Don't try to force the spoiler back down when you've finished cleaning it (as one guy in my garage tried to do!)... whenever you hit around 6mph it'll return to normal position.
magicands
Wed Sep 10 2014, 11:24am
Yeah, as above, put the spoiler in service mode using the screen wiper stalk within 30 seconds of engine shut off.
Spoiler will then deploy to full height and will not retract again until you hit 6mph.
I clean under my spoiler with a damp cloth (not wet) and follow up with a little wax before finally using a little Ferrosol high performance lubricant by Bilt Hamber which I spray on all the iron parts of the mechanism.
Rooster
Wed Sep 10 2014, 12:22pm
Member No: #1799
Thanks for the advice Magichands. I actually used lithium grease on the moving parts. Is this acceptable or should I invest in some Ferrosol?
Wed Sep 10 2014, 02:46pm
If it is dry and not too dirty I think lithium grease is good for the hinges. I use both ferrosol and grease
magicands
Fri Sep 12 2014, 08:29pm
Rooster wrote ...
Both is good.
Norman
Tue Jan 06 2015, 10:10pm
Member No: #364
Mine hasn't got a spoiler, I suppose the 2.2's didn't warrant one!
drummond
Thu Jan 08 2015, 08:55pm
Or a number of other items- so much less to go wrong!
