No replacement air mix flaps available or heater box servicing kit?
joopajaa
Fri Nov 09 2018, 10:24am
Member No: #3261
This is my right hand side - your's drivers side - done yesterday. Let the photos speak from themselves.
One mistake I made: too narrow hole, should have took more from the right side to allow more room for the flap to get out. I did the cutting with "multitool" with 1cm wide metal cutter.
Glued with epoxy and finished with rubbery slicone-like bonding (not done yet on the photos).
4 User said Thank You to joopajaa for this Post :
 trysberg (09 Nov : 13:20) , cruiserphil (09 Nov : 17:52) , eke (10 Nov : 13:08) , e3steve (11 Nov : 10:33)
joopajaa
Fri Nov 09 2018, 04:52pm
Member No: #3261
I also added the "safety" torque limiter 120 Ohm 5W resistors to flap motor wires white (pin 35 + purple (pin 33) in the AC control panel harness - seems to work fine.
2 User said Thank You to joopajaa for this Post :
 cruiserphil (09 Nov : 17:52) , e3steve (11 Nov : 10:33)
Go to page   <<
