wont start
allingkalling
Sat May 31 2014, 06:45pm
Member No: #1261
my 3,0 hdi is accting up again ,somtimes cant start wont turn starter eaven ,faulty handbrake sometimes ,faulty engine somtimes , faulty suspensione sometimes but mostly handbrake warning, and when i leave it for some time it will start but runs high rpm before shift. battery low on charge ? idont have lexia.anything ican check myself before taking it to citroen ?
// janne
Sun Jun 01 2014, 06:36am
A failing battery can cause all sorts of weird electrical issues so get that checked out 1st.
Kent407
Sun Jun 01 2014, 06:38am
Member No: #1732
I would think a battery would be the first to check too.
Our C5 was acting up in a similar fashion when the battery was getting weak.
allingkalling
Sun Jun 01 2014, 12:23pm
Member No: #1261
ok now i measured the battery power. it was 12,4 volts not running and 13,5 when ideling. is that ok ? Any other way to check the battery?
Sun Jun 01 2014, 05:08pm
You need to get a proper test done at an autoparts store that sells batteries, measuring the voltage is not enough
ChrisHunter
Sun Jun 01 2014, 06:16pm
Member No: #188
useful info' on batteries here :
allingkalling
Tue Jun 03 2014, 05:48pm
Member No: #1261
hi charged the battery for 24 hours and it started ok again so mayby the battery is faulty. but iam taking it for annual service at citroen next week .they mayby can determen if the battery is bad and check if the codes says anything else.
allingkalling
Wed Jun 04 2014, 05:48pm
Member No: #1261
started fine in the morning. but this afternoon no way again.!!!!
Iam stuck whith the car at a supermarket . is it possible to tow by Another car and how? or is it better to call a towing Company?
allingkalling
Wed Jun 04 2014, 06:43pm
Member No: #1261
Ok so it started again... when left about 2 hours. next stop citroen garage next wedensday.no driving Before that.
when we tried to start earlier i was listening in the boot area in front and above the battery .and heard a relay that sounded wrong it sounded like it didnt engage just clicked.maybe thats faulty.
allingkalling
Mon Jun 16 2014, 04:21pm
Member No: #1261
the car still at citroen garage. does not start even. changed battery nothing, changed fuse box nothing. No Contact with Engine computor via lexia.....
what else can it be ? ECU ? someting easy and small? but not easy when the car will not talk to the lexia. is it not same Communication with lexia as ex c5 modells of same year. getting a bit desperate.
ChrisHunter
Tue Jun 17 2014, 01:13am
Member No: #188
how about a clogged fuel filter ?
allingkalling
Tue Jun 17 2014, 09:26am
Member No: #1261
it does not turn ower eaven . no Contact whith Engine computer via lexia..
Head display shows wrong on p brake , gearbox fault, suspension faulty . so any ideas of how to get forward in the diagnos of the car.?
allingkalling
Fri Jul 18 2014, 03:05pm
Member No: #1261
no ideas ? car at citroen garage for over a month now .just this week started to do a fault diagnos beaucause some issues whith the insuarance Company.
Not anyone had this problem on a c6 ?
ChrisHunter
Sun Jul 20 2014, 12:13am
Member No: #188
Since it sometimes goes & sometimes not, power connections do seem to be implicated ...
When you changed the battery, how did you do it ... ?
How about jump-starting (as in using another car & jump-leads) ?
Are the earth connections OK ?
Did you have work done recently (six weeks ago, say) which might have disturbed something ?
allingkalling
Mon Jul 21 2014, 06:43pm
Member No: #1261
no work done to it since winter. there is no contact with engine computor so the citroen garage have problems finding fault.... mayby some connector lose or a bad earth somwere but there is a bunch. i`m going by the garage tomorrow to see if there is some progress . i hope .
