Front anti roll link replacement. |
Joe |
Member No: #1633
Hi all. Can anyone point me in the right direction on procedure for replacing front anti roll bar links? Replaced them today but either they arent tight enough or faulty as they knock/click every other second! Seemed a straight forward repair but now its worse than it was. Thanks for any help. |
Joe, if you want to compare with mine, let me know I'm sure we can arrange something if you think it will help.... | ||
Joe |
Member No: #1633
Thanks Steve. I'm going to redo the o/s today and will let you know. Does the suspension need to be in lowest position or doesn't it matter? |
Just uploaded the rest of the front suspension repair guides - Click Here - | ||
Joe |
Member No: #1633
Thanks Dave. Great information and very helpful. | ||
travlician |
Member No: #350
Can't find the manual for replacement of anti-roll bar bushings and links, which one is it (if present)? | ||
travlician wrote ... Can't find the manual for replacement of anti-roll bar bushings and links, which one is it (if present)? Is this 'Tutorial' the one your after - Click Here - ? |
travlician |
Member No: #350
Nope, thats everything for the front suspension with the exception of the anto-roll bar ;( | ||
Well when I set the site up I grabbed every service technical document I could find at the time for the C6, (funded BTW by other sites I owned, which are all closed now). The only way I can think of to find if an anti-roll bar bushing tech guide exists would be to go to service.citroen and pay for an hours access, with no guarantee that one actually does exist. |
travlician wrote ... Nope, thats everything for the front suspension with the exception of the anto-roll bar ;( Hi Travlician, I changed mine last April or thereabouts I posted a few pictures on the forum around the time - Click Here - You need to remove undertray and on one side I think it's the drivers side you need to remove the inner wheel arch liner as well. But I didn't on the passenger side, access was fine. Hope that helps a bit. |
321dave wrote ... I changed mine last April or thereabouts I posted a few pictures on the forum around the time - Click Here - Made a downloadable .pdf from it - click here: - Click Here - |
