Citroen C6 MOT failure rate statistics. |
Only advisories were for engine cover and undertray obscuring inspection. Regards G |
drummond |
My 1939 Light 15 passed with the engine cover and undertray obscuring inspection. Upon enquiry (!) I was told that "they all dó that, Sír". Tim |
drummond wrote ... My 1939 Light 15 passed with the engine cover and undertray obscuring inspection. Upon enquiry (!) I was told that "they all dó that, Sír". Tim What engine cover and undertray! Sounds like they have programmed the system already for some future change to the MOT regime if it's true Tim. |
speedfix |
The tester is simply covering their back. If there is testable items that the 1939 car could fail on that cannot be seen by design etc, so by saying the engine bay is obscured they are saying that they have been unable to fully inspect the car. As with the C6 and many other cars etc, advisorys undertrays and engine covers now hide other wise testable items such as fuel pipes brake pipes. On my car I have the added advisory for the second year of very slight movement on the inner rack joint, still the same as last time, have put it down to some time in its past history prolonged use with a wheel out of dynamic balance. |
speedfix |
[My current one has passed with no advisories but is due again at the end of November and it will be interesting to see the outcome at 5 years old..... ] I suppose in that case you have removed the engine cover an undertray yourself before submitting vehicle for MOT, otherwise the plot will have thickened! |
Certificate refused for mine, yesterday. "Bottom swivels" excessive play. "Don't know why they used that type. Peugeots fail on them as well; they're notorious for it! All the rust around them is a bit of a giveaway" was the comment.... |
jacktherev |
Member No: #1423
sorry to hear that e3steve its most disappointing. It's good to know though and it's something I'll look out for. | ||
I bought this kit today; nailing it in place next weekend. I'm working on the assumption that, at 94,000 miles, the rest of the sheboodle will be pretty worn also, so whilst I'm getting down & dirty I might as well go the whole 324 inches I'll long-term report on the quality (it's not SKF!). At that money I shan't be complaining if it only lasts a couple of years. I'll also be carrying out Speedfix's "grease nipple mod" during surgery. Watch this space..... |
Steve, those are horrible, will have the wrong geometry and lead to increased loading or the joints working loose (possibly dangerous). The Frip joints only really have one failing and that is the sealing, which you are addressing with the grease nipple mod. Regards G By the way, Eurocarparts had proper SKF units available at the same price!!! |
gmerry wrote ... Scheisse!Steve, those are horrible, will have the wrong geometry and lead to increased loading or the joints working loose (possibly dangerous). The Frip joints only really have one failing and that is the sealing, which you are addressing with the grease nipple mod. Regards G By the way, Eurocarparts had proper SKF units available at the same price!!! I read the update about the FirstLine versions being "proper" with the locator barbs, but these seemed to be quite good value compared to all the others I found online. I can send this kit back with just the cost of return shipping. I'll check the quality when I collect the package tomorrow. Thanks for the heads-up, G! |
Update, G: I fitted the FRIPs on Saturday, as I only had 10 days to re-present the car for the free re-test. I checked the kit out very thoroughly, comparing and measuring, with a Vernier, the FRIPs along with the OEM SKF items side-by-side. These new ones aren't so bad after all. The locating ridges are (reasonably) present, they come with new high-tensile steel bolts, the roller bearings are sealed and good quality and the items line up perfectly. I installed each with a grease nipple, as per speedfix's lead, and I reckon I'll never need to change them ever again. Time will tell. The job is so easy I don't really mind if I need to change them out again in a year for two, though. Food for thought? |
