Rear Spoiler With Mind of Its Own
Bishop
Wed Jan 15 2014, 05:34pm
Member No: #868
Dear All, the rear spoiler has been up and down like a fiddler's elbow over recent weeks, and with what seems to be increasing frequency. So, I drive down to the shops, get out the car and it's in the extreme elevation position (I must have maxxed at 29 MPH). It then retracts after the doors have self locked. I then get to a round about and notice that it has elevated (again, having gone no where near the trigger speeds of 78 MPH), a few minutes later and I again notice it has retrated itself. Has anyone had a similar phenomenon? It's not a problem really, I am just curious as to whether it is a precursor to a more permanent problem?
Wed Jan 15 2014, 06:01pm
There is another thread on miss behaving spoilers and I think, it was related to a speed sensor?
 Bishop (21 January 2014)
magicands
Wed Jan 15 2014, 06:22pm
Well its not the motor or the fact that the iron work is seizing. I like Dave suspect a faulty speed sensor or perhaps some damp has got into the system somewhere.
Wait until warmer weather & see if it cures?
1 User said Thank You to magicands for this Post :
 jacktherev (15 January 2014)
DiscoBison
Fri Jan 17 2014, 03:06pm
Member No: #989
I had a similar problem recently, and was simply cured by ensuring the spoiler hinges and sliders were adequately lubricated.
I believe the seemingly random full elevation of the spoiler is due to it's anti-pinch feature, designed stop fingers getting trapped or the motor burning out due to some obstruction. If it attempts to go to full close from the mid position and there is any resistance it triggers the anti-pinch feature. This puts the spoiler into fully deployed mode.
I fully stripped my bootlid lining to understand how the spoiler works. The motor is simply a Webasto sunroof motor driving two flexible plastic toothed strips. These strips pass through the bootlid and move the sliders visible when the spoiler is in the up position. The motor looked identical to sunroof motors used in other PSA cars from a quick glance on ebay. Might be a cheap alternative for a replacement motor if required.
As it turned out just lubricating the exterior components of the spoiler did the trick for me.
6 User said Thank You to DiscoBison for this Post :
 C6Dave (17 January 2014) , cruiserphil (17 January 2014) , gmerry (17 January 2014) , Tjensen (18 January 2014) , Bishop (21 January 2014) , userpco (07 January 2016)
Fri Jan 17 2014, 03:25pm
DiscoBison, I tried the Say Thanks but my server stopped me on this.
I lubricated the slider and hinges when the car was only 14 months old and have never had any problems whatsoever. So it would appear any problems are just down to lack of maintenance
Thanks for the explanation
3 User said Thank You to gmerry for this Post :
 cruiserphil (17 January 2014) , smihaialex (19 January 2014) , jacktherev (21 January 2014)
Fri Jan 17 2014, 06:37pm
DiscoBison,
I second G's thanks. Very helpful post.
Regards,
Bishop
Tue Jan 21 2014, 12:21pm
Member No: #868
likewise - thanks to all, very helpful
jacktherev
Tue Jan 21 2014, 10:24pm
Member No: #1423
gmerry can I ask what you lubricated the slider with please?
Tue Jan 21 2014, 10:49pm
Lubrication was via a general spray with Bilt Hamber Ferrosol over mechanism and a wipe of Castrol CL Grease (or whatever you use for the door hinges and bonnet lock).
The CL grease is soft and water resistant.
2 User said Thank You to gmerry for this Post :
 jacktherev (22 January 2014) , cruiserphil (22 January 2014)
smihaialex
Thu Jan 23 2014, 09:46am
CL stands for Calciul and Lithium... I use the same thing but marketed by Total as LiCa Grease and found it very very effective, even if a bit messy :P
I highly recommend it.
Cheers,
Sam
1 User said Thank You to smihaialex for this Post :
 jacktherev (23 January 2014)
