replacing motor mount (anti basculating) |
citrohanc6 |
Member No: #329
don't know if it's an expression: anti basculating, but the lower motor mount on my 2.2 has gone south. It starts to detoriate which results in axial movements of the engine and some acoustical inconvenience. I've done the trick on the xm once with the transmissionaxle out of the gearbox and a new neopreen mount to press into it's case, but can it be done likewise on the 6 2.2? In other words somebody been there done that? (little chance with only four c6 2.2 owners here but nevertheless) Can someone provide the oem number of the case and mount as sold by citroen or the item itself if sold seperately? (found c5 only) Some French tutorials propose to replace the mount in situ. Is there a way to remove the old metal ring (dremel?) as the neopreen rubbermass can be cut-away fairly easily. Tia, regards Winus |
I can't seem to find any engine mounts in the parts list at the moment. | ||
drummond |
Mine is 2009, so no, not yet. Can you put the jób ón here when you've done it? | ||
citrohanc6 |
Member No: #329
ok, not shure it will be a DIY job... If so a tutorial will be posted. After inspection, it must be possible to replace the mount without removing the axle from the gear box. Removing the empty steel ring from it's case will be the hurdle. On ebay are some amortiseurs that resemble the one that has to be replaced. Okay Enough for now. Regards Winus |
citrohanc6 |
Member No: #329
is this the one? - Click Here - |
That one is for the INJECTION ES9A engine. I managed to find them all though and you can download the correct part numbers: - Click Here - Try - Click Here - to get the correct one delivered to you |
Winus, Looks similar to XM and Xantia. As you changed one before you probably know that the orientation of the rubber bushing is critical. I replaced the bushing on an XM mounting and fitted it randomly! But when I installed the mounting the vibrations transmitted into the bodyshell floor were fairly severe! I then checked the orientation against a Xantia I owned and saw it was different. I then corrected the bushing fitted to the XM (removed and refitted) and everything was fine. Regards, Phil C. |
citrohanc6 |
Member No: #329
oh no a lot of work taking axle und hub apart again. Can we draw the conclusion from the exploded view and the parts list - thanks Dave- that the dimensions are different from XM etc. (EM 2587 QH for instance)? It's not clear from series of cars mentioned that it will fit in C6. The dimension required for C6 are 80x56mm. The oem numbers are 1809 41 until orga. 11283 and 1809 42 from 11284. I need the first one. regards, winus |
Hi Winus, would it be possible to destruct the bush in situ? (make a couple of radial slits in the outer metal bush with a powered hacksaw). Then replace the mount with a custom job, one that is not pressed into the gearbox? Regards G |
citrohanc6 |
Member No: #329
apart from that the bush is halfway destruction yeah think so and the metal ring with a dremel. A hackensaw ok with a fine teeth blade will do. Will this press the mount in the bracket? |
Radox |
Member No: #4044
Can someone tell me how many engine mounts does the 2.7 engine have and where are they located? I plan on changing them all in order to try to reduce the engine vibrations a little. Will it help? | ||
Radox wrote ... Can someone tell me how many engine mounts does the 2.7 engine have and where are they located? I plan on changing them all in order to try to reduce the engine vibrations a little. Will it help? There's three, one on the timing belt end of the engine and two at the front of the gearbox. Of these two, one is under the air intake pipes behind the radiator and one down the back of the engine near the starter motor. The gearbox ones do fail and are expensive if you can find them. Even if they have failed, changing them is unlikely to make any noticeable difference to engine vibrations. In my experience vibrations are caused by other problems, most notable being ignition/fuelling issues. Start by trying the car on premium fuel. Then check the glow plugs are working properly, check the fuel pressure and have the injectors cleaned and tested. |
Radox |
Member No: #4044
MGmike wrote ... Even if they have failed, changing them is unlikely to make any noticeable difference to engine vibrations. In my experience vibrations are caused by other problems, most notable being ignition/fuelling issues. Start by trying the car on premium fuel. Then check the glow plugs are working properly, check the fuel pressure and have the injectors cleaned and tested. How many fuel injectors does the car have? I guess six? And what about the glow plugs? My car is a 2.7 Diesel. Aren't they needed only upon starting the car? How can they be connected to the vibrations during driving? |
Radox wrote ... How many fuel injectors does the car have? I guess six? And what about the glow plugs? My car is a 2.7 Diesel. Aren't they needed only upon starting the car? How can they be connected to the vibrations during driving? well that was an important bit of information you missed out "during driving"! Yep six injectors and six glow plugs. Glow plugs continue to run after starting for about 5mins to help with ignition while the engine is cold. They do help to smooth the idle a bit. If the vibrations are noticeable while driving normally I would be looking at the injectors or possibly a gearbox problem. |
Radox |
Member No: #4044
All right, I finally found time to bring the car to the dealer. I will be changing all the engine mounts, the gearbox oil (3 litres only) and the glowplugs. Will keep you updated on the results. They gave me the following list of parts to be changed, in connection wih the mounts: 1813G9 1846A3 189032 1880C3 180675 1807Z7 1813A1 1813C3 1813C5 1813E4 These are the two gearbox mounts, as well as two other elastic mounts (one of them callen "Silentblock" hehe), some brackets etc. Can someone confirm if these are all the needed parts in order to fully renew the engine mounting, or there are some more? |
