Suspension problems
adam
Thu Sep 26 2013, 12:15pm
Member No: #999
Hi recently my suspension has started to drop at the rear immediately after switching the engine off. Also the engine has to be running before the suspension comes back up to the correct level rather than when just "bliping" with the keys. I know that there is a fault and will have to book the car into the dealer, but my questions are:
1 Is this going to be expensive to fix?
2 Is the car safe to drive?
3 Will drive damage the car further
Thanks
Adam
Thu Sep 26 2013, 12:31pm
I am not an expert, but after 30 years with hydraulic Citroens:
1 Impossible to say, i will guess not very expensive (valves, pump, wheel cylinders, spheres being the suspects)
2 Yes, difficult to imagine a reason that maks the care unsafe
3 No, probably no more wear than in a normal situation, just wrong flows for a reason or another. But check fluid level and that the pump is not running hard all the time.
 adam (26 September 2013)
travlician
Thu Sep 26 2013, 02:52pm
Member No: #350
I had a problem similar caused by a sticking valve in the rear unit (the one with the two spheres). Cleaning the valve has helped (and is still good after almost two years) but the official Citro├źn remedy is replacing the entire unit. Is it dangerous? Yes if the car drops while driving as there is no rear suspension at that time and the clearance below the car is very tight. Mine did drop down while driving in the week before fixing it, but before that it just was slow in raising after starting (tended to drop on unlocking the car but not always). If you feel any pronounced bouncing while driving you better stop and see if you can get the car raised again before continuing. I just a piece of metal to tap the valve body in emergency and got the car to raise like that... I was glad it was fixed!
1 User said Thank You to travlician for this Post :
Thu Sep 26 2013, 09:59pm
Adam,
I had a similar problem and it was Travlician's experience that helped me fix it. Have a look at this forum page Here, See what you think.
Regards,
 adam (27 September 2013)
magicands
Sat Sep 28 2013, 06:20pm
My suspension does not rise with a "blip" of the key, the key has to be in the ignition and the ignition has to be on before it sits up!!
Sun Sep 29 2013, 07:44am
magicands wrote ...
Well your the odd one out again as mine rises as soon as you unlock the car......
Sun Sep 29 2013, 03:09pm
magicands wrote ...
Mine does too.
Sun Sep 29 2013, 05:21pm
Member No: #82
Ditto - although mine normally sinks slightly!
Sun Sep 29 2013, 07:17pm
And mine- (checked today)Blip-whirr-slowly a few cm up. DS, CX, XM was faster with the engine running, but of course nothing happened before that. Turning off: a few cm down after some seconds. C5 probably as C6 ?
(Had to refill 0,7 liter a few weeks ago, the garage said it was normal: that LDS "disappeared" a little, probably through the steering.
speedfix
Mon Sep 30 2013, 06:46am
Mine is ok, lifts a little to normal height once the car is unlocked with the mirrors folding back.
No suspension issues as yet.
The car in general has been outstanding.
Trip to portugal soon, taking the lap top lexia and auto data as this seems to work well with probs on PSA, may take the solus as well.
IMO multi meter is a must for pinpoint testing.
smihaialex
Mon Oct 07 2013, 09:54pm
Hey @magichands, you are not alone - my car is the same - it sits up when key in ignition and half turned, not when unlocking...
Are we sure that this is a fault and not by design?!?
Maybe earlier cars were built like this - up on ignition, not on unlock?!?
Or maybe there's a setting for this accessible via Lexia/Diagbox only?!?
Thanks,
Sam
Tue Oct 08 2013, 07:16pm
Well Sam,
Both of our cars are 2006 build and both run the suspension pump when you unlock to stabilise height. I always thought this was the idea to get around the delay with older models having to start the engine and wait for the car to rise? With the C6, the car has achieved height by the time you get into it for the quick getaway!
Regards,
 smihaialex (08 October 2013)
dsharples
Tue Oct 08 2013, 08:41pm
Member No: #119
Is there actually two things happening here. (1) When the car is unlocked, the car returns to a standard "reference height", and (2) When the key is turned in the ignition, the car moves to its proper self-leveling operation to "compensate" for the fact you are sitting it it etc.
I was told it only lowered when "parked" as a design aesthetic...
Tue Oct 08 2013, 10:13pm
Yes, it is 2 steps. The lowering when locking is aesthetic, but I also heard that it is the right hight for stepping out and unloading.
smihaialex
Tue Oct 08 2013, 11:23pm
Well, I see your point Phil
However, there could be another logic at work here - it lowers itself when turning off the ignition to help you get out of the car and also to help with unloading your luggage, right?!?
So then, wouldn't it make sense to stay down after unlocking to help you load your luggage and get inside the car, and only get back up on ignition, when presumably the luggage has been loaded and the passengers and driver are all aboard?!?
I'm not saying that this is right, I'm just thinking out loud...
However, exploring all the possibilities, if it were to be something wrong with my car, what would/could it be?!? Everything works well on demand (pressing the buttons takes the car to the desired height in a timely fashion). When ignition half turned, normal position is reached fast, with no noises or hesitation. Everything seems to be just fine. Are we sure there isn't a Lexia setting on this?!? Set to 'Bank Robber' on your cars, Phil, and to 'Shopping Housewife' on mine
Thank you,
Sam
PS: Mine also lowers when ignition off, not when locked
1 User said Thank You to smihaialex for this Post :
 cruiserphil (09 October 2013)
