C6 PARAMETERS which could be changed
urb
Sun May 09 2010, 09:03pm
Member No: #26
2 funny functions is:
Presence of the welcome function for the driver == driver seat goes back if ignition is off and you opens the door and back to position when ignition is turned om again, guess the steering wheel also goes upward if electric handled.
BMW has this activated on the US market.
Presence of the welcome function for rear passengers == backseat goes fully back when the passenger door opens, but there is no memory function here so it will not return to original position ( applies to Lounge)
CUSTOMER OPTIONS
Underinflation detection type
ABSENT
Driver's seat belt not fastened detection
Yes
Daylight driving lights default illumination
Yes
Simultaneous illumination of the side lights and daylight driving lights
Yes
CONFIGURATION
Overspeed warning for Arabic peninsula countries
Passenger seat memory unit option
Present
AUTOMATIC GEARBOX OPTION
Present
Right hand drive vehicle
No
variable suspension option
Present
Engine oil temperature sensor option
Present
coolant level sensor option
Present
Presence of Telematics Unit (RT3 / RT4)
Yes
Water in diesel sensor
Air pump present
No
Driver's position memory option
Present
Presence of a trailer relay unit (BSR)
Yes
From oil temperature information
Engine relay unit
Parking aid button present
Yes
Type of parking aid
Front and rear parking proximity sensors fitted
Warnings log present
Yes
Parking aid with visual information display
Yes
Parking aid with audible information
Yes
Type of fuel cap fitted detection
by the BSI
Diesel additive pump control
No particle filter
Alternator type
Standard
total duration before maintenance (limit in months)
12
First maintenance limit (km)
0
maintenance limit (marketing) (km)
20000
Distance limit for forcing customer mode (km)
250
Memorizing of faults
Forbidden
Distance limit for automatically switching from parc mode to customer mode (km)
1
No
Electrically operated rear seats
Yes
Yes
Yes
Rear passengers' seat belt not fastened detection
No
Front passenger's seat belt not fastened detection
Yes
RD4 radio present
No
Reference tolerance
2.0
Unintentional line crossing warning option
Present
Presence of a fuel pump
Yes
Presence of head high vision
Yes
Presence of a moving boot spoiler
Yes
Detection of rear centre passenger seat belt not fastened
Yes
Detection of rear left passenger seat belt not fastened
Yes
Detection of rear right passenger seat belt not fastened
Yes
Speed threshold for displaying the warning: high speed tyre inflation pressure (km)
190
Type of sound from the indicators
Standard
Pollutant sensor present
No
Presence of blowers to relay the main blower
Yes
Type of additional heating
Air conditioning compressor drive ratio
1.19
Type of climate
Temperate (-17°C to +37°C)
brightness sensor option
Present
rain sensor option
Present
Automatic hazard lamp illumination in event of impact option
Hazard lights illumination on heavy deceleration option
Present
Illumination of hazard warning lamps on pressing emergency call button
Inactive
Directional headlights present
Yes
Presence of directional headlamps with diagnostic capability
Yes
Yes
Yes
Locking when moving option
Present
sunroof number / type
NO SUNROOF
Central locking present
Yes
Alarm type
Standard alarm
theft-proof mode
Active
When unlocking using the high frequency remote control unit:
Unlocks the driver's door only
Type of harness for the window descent micro unit
New harness
fuel type
PETROL
Oil level sensor option
Present
tank capacity (l)
73
Fuel sender law - warning level (L)
7.0
Vehicle selection - fuel sender law
Petrol vehicle
Oil dipstick programming - engine type
Petrol 3.0 L (V6)
Origin of oil level information
:Engine relay unit
ECUS PRESENT
Switch module at the steering wheel
X
Airbags
X
High frequency receiver
Engine Relay Unit
X
Boot control unit
X
Pedestrian impact detection unit
X
rain / brightness sensor
X
Driver's door module
X
Passenger's door module
X
Driver's seat plate unit
X
Passenger seat plate unit
X
Built-in Systems Interface
X
Rear seat electronic memory unit
X
alarm
X
parking assistance
X
Control panel
X
radio
X
NaviDrive telematic unit
X
display
Trailer relay unit
X
Air conditioning
X
Driver's seat memorizing unit
X
X
High level display computer
X
audio CD changer
X
Hands free kit
Boot lid mobile deflector
X
Windscreen wiper
X
steering wheel angle sensor
X
engine management ECU
X
Auto/manual controlled gearbox
X
ABS ECU/ ESP ECU
X
Tyre deflation detection
X
Variable shock absorbers
X
Suspension
X
Electrically-controlled parking brake
X
PAS
X
Lateral speed and acceleration sensor
X
Additional heating
Mon May 10 2010, 06:21am
Thanks for taking the time to compile this, very interesting.
Just needs access to Lexia/Proxia to do it.
smihaialex
Tue Dec 18 2012, 02:18pm
So, quick question here - are you sayin' that through Lexia I could activate the Welcome function for the driver seat?!?
You see, the reason I ask is because, here in Romania parking spaces are not intended for bigger cars such as the C6 which barely fits in the largest of supermarket parking spaces, so the presence and activation of the welcome function would allow for better access in and out of the car with the doors open to the first nudge
Thank you,
Sammy
Tue Dec 18 2012, 04:20pm
Se in the cars own menu (no Lexia needed) Under "access".In mine I can able/disable the steering wheel retraction when seating from there.
smihaialex
Tue Dec 18 2012, 09:13pm
@TJensen: Could you please indicate the whole path to that menu, but I'm sure I have looked and I haven't seen that setting... There are some greyed out settings - settings that I cannot access... Is it possible that it's been disabled and can be re-enabled via Lexia (just like the DRL option for non-German C6s)?!?
Thanks,
Sam
Wed Dec 19 2012, 07:43am
If they are 'greyed Out' it means they aren't active and yes you would need to enable the function (if available) via Lexia
smihaialex
Sat Jan 12 2013, 10:38pm
@Dave: I went to my local service shop and they even let me take a look around Lexia and I just couldn't find the section where to enable this... We did switch Presence of the welcome function for the driver from No to Yes, butbthat didn't do anything really...
Help please.
Thank you,
Sam
pclark
Sun Jan 13 2013, 10:28am
Member No: #3
I'm pretty sure the 'welcome function' on the C6 only operates the powered steering wheel movement and not the seat. On the C5 it does move the seat where fitted.
Sun Jan 13 2013, 12:21pm
pclark wrote ...
That's all it does for me but, if you have 'memory' seats (Exclusives mainly unless you have a Lignage with full leather) you can push the seat back before leaving the car and simply press the memory when getting back in to move it forward
Sun Jan 13 2013, 02:22pm
Sorry, I have no Lexia competence yet (bought the stuff, but....) My garage used a lot of time to search for the sub-sub menu wakening up the daylight running lamps, found 2 options and chose the wrong one. But it is there and will work. If headlights are not turned on automaticly they will start, with or without sidelight/parking lights.
And yes: the option for access is just moving steering wheel out of the way until "ignition" is on.
urb
Fri Feb 22 2013, 11:08pm
Member No: #26
Had the welcome function for the driver/driver seat activated for i while.But I
turned it off ( like to have the seat in the same position, going in and out).
I have the Lounge model, could be a factor.
akabigm
Sat Sep 07 2013, 02:17pm
Member No: #1302
Is it possible to make the cruise control stay on, ie ready for setting not at a speed obviously ? rather than having to press the button to activate it, which is still on my car unpredictable and needs the steering wheel tango some times, though even that doesn't always work. If iot came on as standard with ignition, my Volvo C70 would do that
Sat Sep 07 2013, 02:25pm
Don't think you can I'm afraid.
Pappnase
Mon Sep 09 2013, 09:08am
Member No: #1044
There is one interesting option "coolant level sensor option". Does that mean you can retrofit a coolant level sensor?
I had the notorious coolant tube failing two months ago and would have appreciated an earlier warning.
Mon Sep 09 2013, 09:50am
There is a thread on that particular subject already
