Rust
Sun Jul 07 2013, 08:01am
Hi all, where I live, lots of 8 year old Mercs with bubbling rust spots: not just a Citroen problem.
Wed Jul 17 2013, 09:30am
Rust specialist companies and independent organisations tell tales of a new rustwave in cars, problems of the industry. Mercedes among the worst (??)or only the brand with the most disappointed customers(??). My impression is that the C6 is basically good, BUT have lot of details that need attention to keep rust away (spoiler hinges, small parts in doors, parts of the wheel and suspension system, the engine cooling pipe, lots of screws, nuts and washers etc). Small things they did not think of (??) I will periodically walk around the car and check (also the underside) with my spray cans... Maybe we can make a anti-rust guide ?? The first point will of course be to pay for a full extra independent antirust treatment after getting the car.
Wed Jul 17 2013, 12:36pm
Just in from changing air filter. Found too much surface rust and corrosion in the engine compartment. Tubes, screws, links ; all kind of parts. Sprayed with standard universal spray. Did not like it. Is too much rain and snow and... coming in while driving ??? (Car is 2010, use garage and use the grille blind in winter)
Wed Jul 17 2013, 01:00pm
Hi Tjensen.
EU legislation has severely curtailed plating options for fasteners (anti-corrosion), some of the newer alternatives just don't work!.
Try removing the threaded mudguard liner fasteners, heads will be gone and threads seized up. Its things like this that make a simple job into a headache.
Agree with you on the Mercedes. In Scotland, many 5-6 year old Mercs have rust around the wheel arch lips, just like a 1970s car. Fords are rubbish by the time they are 10 years old. Citroen body stuff is very good.
mark28
Wed Jul 17 2013, 07:59pm
Member No: #102
Mercedes Benz followed a disastrous plan in term of paint until the decoupling with Chrysler. Paint is much better now. The other point with a merc is that as long as it as been serviced they will always honour the anti corrosion warranty .
Rettopian
Wed Jul 17 2013, 08:19pm
Member No: #1195
Forgive the pun - but didn't the rot set into MB with the W210 model that replaced the W124? From memory this was the car they developed partly in a 'water' rather than wind tunnel but more importantly, it was the first model where the accountants had the whip hand over the engineers.
The quality of the current models - well the larger models - seems to be pretty good though.
Thu Jul 18 2013, 09:03am
(In Norway there are still issues with MB and rust, but of course it is a bit like software: the latest edition always have "solved" the problems. And it might be true....)
What can I use to protect bits and pieces around the engine from rust ? Tectyl/Waxoil can melt and burn ? Paint is difficult to use etc ? I will not take tings apart, and it is "new" and clean inside
Thu Jul 18 2013, 10:20am
Bilt Hamber 'Ferrosol' is good - Click Here -
nickyg
Thu Jul 18 2013, 12:06pm
Member No: #100
Bilt hamber "dynax" would likely be even better for this purpose, though ferrosol is great for a plethora of applications. I think there are two versions now, a clear version, maybe. I've used "dynax UB", which is a brown colour.
Thu Jul 18 2013, 12:15pm
Thanks Dave and Nick ! Ferrsol is not usual in Norway, but I have seen it and will search. Basically this is a high quality universal spray, way above WD-40 and CRC ? (of the two the CRC is maybe the best and 6-66 is better than 5-56 in costal areas ?)
Thu Jul 18 2013, 12:36pm
'Dynax' is a better version of 'waxoyl' and what I used to protect all the internal cavities on the Traction after the re paint.
It will be messy in the engine bay leaving a visible coating which is why Ferrosol is better
BTW the link I gave is to Bilt Hamber web store where you can buy the product direct
Thu Jul 18 2013, 03:17pm
Difficult and expensive to import Ferrosol to Norway. Maybe it has a different trade name here ? I found CRC SP 350 II, a product for protecting from corrosion during storage etc Penetrating and lubricating as well. I will use that and a traditional light "Waxoyl/Tectyl" type for things not directly attached to the engine.
Thu Jul 18 2013, 04:19pm
I would have thought that as it's widely used in the offshore oil industry, it would be available in Norway.
Sun Jul 21 2013, 09:31pm
Found in a Norwegian postorder shop and orderd 3 cans
Thu Aug 01 2013, 07:20pm
The Norwegian postorder company Kraemer /Gasolin have delivered BiltHamber Dynax and Ferrosol to competitive prices ! Recommended
Go to page   <<        >>
