Air Conditioning not blowing cold
lrhart
Mon Apr 26 2010, 12:44pm
Member No: #97
Hi, the air-con on my C6 Exclusive (2007 2.2HDI) has now stopped cooling. The outside temperature sensor is reading correctly, the fuses are OK, and the air-con is enabled in the menu. Warm air is fine, but now summer is here its getting a bit warm.
Anybody have any ideas? Sensors, if so where are they? I would expect the refrigerant to be OK, it has been regularly serviced, now just over 30,000 Kms (not miles!).
Thanks,
Les
Mon Apr 26 2010, 12:47pm
Welcome from sunny Spain
The Air Con system isn't part of routine servicing I'm afraid and the refrigerant should be 're gassed' every 2 years so that's the first thing to have checked as a lot of people overlook it.
If it's low then the motor won't run as the refrigerant also contains a lubricant.
lrhart
Mon Apr 26 2010, 12:53pm
Member No: #97
Dave, many thanks for the prompt reply. I will take it in tomorrow and see what the garage thinks. What should be the approx cost for a re-gas (in the UK)? Labour rates are a lot cheaper here I think.
Mon Apr 26 2010, 12:55pm
My local Citroen Dealer charges £30.00 - the Peugeot dealer near me wanted £99.99!
It really does vary I'm afraid.
You may be better off going to a specialist Auto Air Conditioning company and getting a quote there
lrhart
Wed Apr 28 2010, 01:27pm
Member No: #97
Fixed now, re-gassing and lubricant required. There appears to be no diagnostic code logged when the refrigerant is lost, a bit surprising from Citroen considering the nagging they give about rear seat belts! Thanks for the info.
Les Hart
Wed Apr 28 2010, 01:36pm
Don't think there is a sensor anywhere to look at refrigerant level/pressure
A lot of other 'faults' aren't actually logged either so if any do appear intermittently, grab a picture with a mobile or camera to prove to the dealer hat the error actually appeared.
If it stops cooling again then there may be a pinprick hole in the pipework or matrix (a few have failed this way on the C4)
ststech
Mon Dec 29 2014, 06:37pm
Member No: #1845
my ac compressor is not kicking in now the weather is -3
it was working ok in the summer but no longer cuts in there is refrigerant in it
any ideas
also how easy is it to replace the heater mixing flap reduction motor
as mine adjusts but doesnt go all the way
ie the passenger side is hotter than drivers side
help appreciated
Mon Dec 29 2014, 07:10pm
The AC will not work at -3, that's quite normal.
ststech
Tue Dec 30 2014, 11:12am
Member No: #1845
Admin may want to put this somewhere else
but it is relating to mixer flaps in heater box
it is available for the c6 as repair kit at £69 inc vat
it is the same kit as the Peugeot 407 and C5 mark 2
Citroen Peugeot part number 6480E3
hope this helps
Tue Dec 30 2014, 01:22pm
ststech wrote ...
Can't move individual posts, only whole threads.............
ststech
Wed Dec 31 2014, 10:43pm
Member No: #1845
couple of questions
what is the low outside temp level that prevents ac compressor starting
the other question is drivers side on my car no heat regulation i put hand up and felt reduction motors
the distribution motor is operating as i can feel it when adjusating the air distibution
yet when adjusting the temp the mixer flap reduction motor does not move at all no vibration or movement felt like the other reduction motor
i am going to try and remove the mixer flap reduction motor but cant without removing the knee airbag but can find no reference as to how knee airbag and odments box are removed found nothing in download section can anyone advise
thanks in advance Simon
blackhatphil
Sun Jul 09 2017, 11:02pm
Member No: #882
Hi All
I can see this is an old thread, but the title is relevant to my problem so I thought best to post it here.
My 2008 2.7 was blowing warm air so rather than pay the £99 pound at the dealer I took it to Halfords for £49.99. They reported that it was indeed low on gas, so the topped it and it was icy cold - for about 2 weeks. Now it is blowing warm air again.
If the gas is low again (I'm going back to Halfords tomorrow) does that indicate a serious (££££) problem...?
Cheers!
Phil
Mon Jul 10 2017, 08:45am
Hello Phil,
Does indeed suggest a leak. The condensers are known to fail. There are posts on this in the forum back a bit if I remember correctly.
