How do you remove the front fog lamp lens? |
Stealth |
Member No: #986
My front fog lamps have a swirling white residue on the inside of the lens that I'd like to clean up. The black plastic embellisher that surrounds the fog lamp/daytime running lamp/indicator easily unclips but I'm not sure how to remove the fog lamp lens. As it appears to be glass, I don't want to apply too much pressure to lever it out. It doesn't seem to turn or unclip. Does anybody know if it can be removed? The manual says to consult a Citroen dealer when the bulb needs replacing. While it's not easy to see the swirl in this photo, it's noticeable to the naked eye. |
The lens is 'Bonded' (glued) to the unit so it's very hard to remove. It would be simpler to buy the new unit complete and swap it over. |
Stealth |
Member No: #986
Glad I asked. Thanks Dave. |
The units are normally 'Valeo Fogstar' used across the whole Citroen/Peugeot range. Citroen part number is: 6206E1 However you may find that a 'Samlip' part number 6206Q3 is used Bulb BTW is a H11 12V-55W It appears that they are used acros a wide range of cars as well. There's a pair on eBay atm for a 2009 Focus RS - Click Here - at £60 |
travlician |
Member No: #350
"The black plastic embellisher that surrounds the fog lamp/daytime running lamp/indicator easily unclips" but how? Just pry it off I tried but didn't budge with little force and don't want to break it? Or are there some bumper/bottom parts to remove first? | ||
Stealth |
Member No: #986
Hi Travlican, It's really easy. Just place your fingers behind the centre facing edge of the car so you get a good grip, then give a firm pull outwards. The plastic is quite flexible so I don't think there's much risk you'll do any damage. You don't need to remove anything else first. I've taken a photo to show you where to locate your fingers. |
