Greetings from Preston (part 3) |
![]() ![]() Member No: #3151
Steve, I think it's just bad luck/timing m8! There are no ABS connections anywhere near the bumper. There's only the two plugs on the off-side for the lights, parking sensors etc. Is your battery fully charged after standing a while? Otherwise it's a plug in and check the codes day. Good luck |
Mike, Thanks kind of what I figured, I’m off on Tuesday, will get diagbox plugged in....... can’t wait ???? |
OK, so the saga with the ABS was down to my own stupidity ![]() Quickly resolved by Robert at BL Autos. Next we have the towbar, which was put on the car whilst I was at BL Autos and worked perfectly, until I got home and decided two weeks later to take the car out for a run. I got the "rapid" flash of the indicators, like when you have a bulb out, and the reversing sensors stopped working. After playing around with the 13 pin socket I noticed a bent connection and straightened it out and the rapid flashing stopped. GREAT!!! Nope, I've had the same problem again today, so I got Lexia connected and removed the Trailer relay in the BSI and the disabled the configuration. now I have the indicators flashing correctly but the rear parking sensors are disabled and I can't find anywhere to enable them. ![]() |
