Everything I have found about the RT4/5 and USB (and phones and Bluetooth)
pclark
Tue Jul 24 2012, 07:07am
Member No: #3
As michaelb says you undo the two Torx screws (T10 from memory?) which are in the small holes at either side of the head unit facia panel. You will need a long torx bit or screwdriver type as the screw heads are too recessed for a normal socket set type bit. The head unit then simply pulls out. The 'extractors' are probably for RT4 when used in other Citroen/Peugeot models.
Dapprman
Tue Jan 28 2014, 10:35am
Member No: #710
Necro time ...
I got a cable fitted to my RT4 unit today (well colelcted the car today). If I put a pen drive in I get a Recognising CD message (as you do with a firmware/speedcamera/map update), but then nothing. The drive is set up as follows
D:\>dir
Volume in drive D has no label.
Directory of D:\
19/03/2009 10:39 55,731 BUILTINS.OUT
19/03/2009 10:40 77 BUILTINS.OUT.inf
28/01/2012 12:03 111 POI_VER.POI
27/01/2014 13:50 <DIR> UPG
27/01/2014 13:49 <DIR> CMD
D:\CMD>dir
Directory of D:\CMD
27/01/2014 13:49 <DIR> .
27/01/2014 13:49 <DIR> ..
13/11/2009 11:12 7,566 CONFIGFLAG.CMD
and nothing in the UPG folder. Am I missing some thing ? I'm running firmware 8.31 so could this be an issue as well (i.e. too high).
Cheers for any help
Dapprman
Tue Jan 28 2014, 12:11pm
Member No: #710
Now sorted - was missing the POI_UPGRADE.CMD file from the UPG folder - if I'd just uncompressed the Mirascripts zip on to the USB drive it would have been fine
Aeth
Thu Jun 02 2022, 11:35am
Member No: #4760
Hello,
I'm planning on installing the 6574.JH cable to play MP3s in my new C6 and I was wondering whether the system is very picky when it comes to USB sticks?
I would like to buy a 128 GB USB 3.1 one. It should be backwards compatible with the systems' USB 2.0 standard, but I'm not sure whether the size will confuse it or not?
Otherwise I'm aware that it has to be formatted to FAT32 and that the max. number of songs recognised can be updated via the Mira script.
Merci!
CorneSoutAfrica
Mon Sep 05 2022, 08:13am
Member No: #2836
Hi Aeth
Where did you source the cable? I am looking for one at the moment
Aeth
Mon Sep 05 2022, 04:42pm
Member No: #4760
Hi, I googled “6574 JH USB” and after a while found it on a polish (or czech?) website called Allegro, kind of their version of eBay. Found both an original one from an ex Citroën dealer who had some old stock left and a not-so-original one from a different seller. You can try to see if there are any left on there, otherwise I also remember seeing a few Chinese ones on eBay. They all had brown plugs for some reason, but I imagine they should do the job just as well : )
Go to page   <<
